HD dozers |
7060
Joined: 16 Sep 2009 Location: Missouri Points: 1155 |
Topic: HD dozersPosted: 02 Mar 2010 at 10:39pm |
What are some of the pros and cons to a allis HD with the torque converter? Ive heard good and bad. Some say that they are prone to failure, and gutless. What about the transmissions and final drives? Is there somewhere I could go to read about them? thanks
acisbest
Posted: 03 Mar 2010 at 8:00am |
I know a little about the HD6G, not too much about the others...
The main failure point on the HD6G was the pinion gear on the rear drive. I knew a guy in Frederick MD that used 3 HD6G's. He had replaced 2 pinions and said another dozer was about ready to bust its pinion... Other than that he said the HD6G was a good machine. You might try IBDOZING.com, forum is not that current but there is some history there. |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42269 |
Posted: 03 Mar 2010 at 9:42pm |
The final drives on the HD6 are the same as used on the HD5 machines. Most failures I have seen are from outboard bearing at top of rear case failing and breaking case. Other problem is the rear transmission double row ball bearing going out .
I have replaced 2 of the trany bearings (pinion shaft) as well as the bearings on the ring gear support. Also all new internal trany bearings and bushing on reverse ideler.
Torque converter will have less power to track but make it easier to control machine functions. The HD4 I had with torque converter took some getting use to in using decellerator pedal. Now the 715B TLB with torque converter is great .
The FD5 uses a torque converter but also has power shift trany and is great for grading and most light work i do with it .
7060
Posted: 03 Mar 2010 at 10:55pm |
My great grandpa bought a new HD 11 in the 60s. My Grandpa used to run it and said that it wouldnt kill its self but rather slip the torque converter. He said there was always something goint wrong with it. I just found it hard to believe that Allis Chalmers did so well on tractors and there were problems like this on the industrial side, but maybe it was just this one. Ide like to have a HD series, but was kind of weiry of one. thanks
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35679 |
Posted: 07 Mar 2010 at 12:54pm |
A cable layer commercial phone and internet underground trunk line conduit installer is still using two old HD16s' he prefers them to cats as they are easier to operate and less likely to cost him a fortune when they do need work. The mechanic there did say parts are getting mighty thin and they may have to retire the old dogs.
BobsAc
Joined: 14 Oct 2010 Location: Lakeside, CA Points: 19 |
Posted: 14 Oct 2010 at 6:48pm |
Later HD-6's used different bull gears and sprocket shafts than the HD-5/early HD-6's.
BobsAc
Posted: 14 Oct 2010 at 6:53pm |
They made several different models, early ones used diesel fuel from the fuel tank and tended to heat up if the tractor fuel tahk was run too low...Later ones generally corrected that problem... the input shaft on the tranny was a ball bearing type which some contractor's complained of failure there... Otherwise they had a long successful run... (Early Cat D9 Torque converter tractors also used diesel fuel similar to AC).
