HD 7 G engine problems
Message Reverse Sort Order
Chitwoodshan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chitwoodshan Quote  Post ReplyReply Direct Link To This Post Topic: HD 7 G engine problems
    Posted: 30 Aug 2011 at 12:10pm
Thanks guys ! I'll look today.   My wife is after me to sell it for scrap but I couldn't do it. The machine worked great until engine failure. Hyd. , undercarrage, brakes , 4 in 1 bucket.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2011 at 5:21am
 If you have a motor 6 cylinder your machine should be a HD7GB WITH 3500 motor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2011 at 8:02pm
FIND THE "TAG" RIVETED TO THE LEFT SIDE ?? OF THE ENGINE....I THINK YOU HAVE A 3500 SERIES ENGINE.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chitwoodshan Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2011 at 3:15pm
I've got to figure out which engine I have. I know its a 6 cyl. with turbo but thats all I know. What's the best way to Identify which engine I have?
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 4:13pm
I thought a 7G has a 6cylinder 426 in it an overhaul kit is like 1200 bucks, if you need a 7000 series engine I have 2 new ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 3:46pm
I dismantled some HD7G for parts if I can help with used parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chitwoodshan Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 3:39pm
Thanks I'll check with him.
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2011 at 3:55pm
there not that hard to rebuild its just parts are a little expensive here is a phone number to west rock company that deal with ac parts in little rock ar 501-228-0330- mr jones has 7been an ac man for years since i was a kid . someone was selling  surplus  7000 engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chitwoodshan Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2011 at 2:30pm
The engine started loosing oil pressure after in ran for 10-15 mins.  The machine sat for about a year and I had to move it. Put in new batteries and machine cranked with starting fluid ( not much ) . I lifted the bucket and it chattered so I throttled down and machine went dead. Added 5 gals of Hyd. fluid and went to restart but all engine would do was bump, fan would move about 1 1/2 per starter bump.  How hard is engine to rebuild? Could this be a spun main bearing? or any Ideas.  I've rebuilt plenty of gas engines but no diesels.
This page was generated in 0.191 seconds.
