HD 6 Gasket
kinghunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Topic: HD 6 Gasket
    Posted: 28 Jan 2015 at 8:47pm
Well got a couple projects going on at same time lol. who doesnt? well working on the allis chalmers hd6 and it needs a head gasket. now the question is where can i get a new top end gasket set? it has the old non turbo buda engine in it. will have to look again but believe engine tag reads hd 6 b 344. any advice to where to find one would be appreciated.
Norm Meinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2015 at 10:12pm
I can get the head set for you. call 815-865-5372
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2015 at 6:14am
if for some reason norm cant help you can try minnpar
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2015 at 7:12am
When I rebuilt my HD344 I got parts from Syracuse Crank & machine
(800) 437 3609 I have seen their auctions on eBay for HD344 motor parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2015 at 7:24am
My HD6G was using coolant. As I was cleaning the top of the block to replace the gasket I noticed that one of the sleeves was loose. When I removed it I found it was cracked at the top of the ring travel. It came out in 2 pieces. That was my coolant leak, not the gasket. I put an in frame rebuild kit in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2015 at 9:02am
ive pulled head its  the head gasket for sure, completely gone between a oil jacket on front cylinder and gone between a water jacket on 3 cylinder back, thanks for all the info and help. now the question is i dont have a book so what is the torque specs for head bolts?
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2015 at 9:22am
KH: From Allis Chalmers Service Manual for HD6 crawler tractor prior to s/n 1332 -
All 5/8 nust must to tightened to a torque of 190 to 200 lbs. ft. " and the 1/2" nuts to a torque of 95 - 105 lbs. ft.
Quote - "After the first 10 - 100 hourse of operation the cylinder head studs must again be checked"!
Page 90 of the manual Fig.   4 shows the sequence of tightening the cylinder head stud nuts - sorry don't have a scanner.
HTH's....
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2015 at 9:38am
well i guesse where going to go ahead and put an inframe in the old girl. I was just going to repair it but everything is in such good shape my father talked me into doing a inframe on the engine. is there anything i need to know about before we start digging in. any tips or secrets. Also I know where one of these are with a turbo on it for a descent price is it difficult to switch motors?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2015 at 6:31am
When you park it for the rebuild, think about how you are going to deal with the oil pan. I always put the track on timber at least 4 inch thick.
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2015 at 11:33am
The turbo`d engine should go straight in where the Buda is. If that one has the oil master clutch bolted to it, all the better
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2015 at 6:55am
The 7000 motor is much better than the HD344. Some of the surplus motors were rebuilt before they were sold at auction. The motor fits directly. Some accessories may have to be taken from the HD344. You may have to cut the hood for the new exhaust position. The cast iron exhaust manifold on the 7000 motor is a prize part. It will be less expensive to transplant rather than rebuild.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2015 at 7:57pm
ok guys i'm alitle confused when  you look up kits online it dont show a head gasket for non turbo or turbo it displays the kits as they will work in all the engines? is this correct? as some people have told me that the ones with injectors going straight into head use different parts then ones with injectors angled into head. well alittle guidance here would help when i order my kit. also i was looking at the agkit.com site.
thanks again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2015 at 8:11pm
There were different pistons used to match the various injectors that were used over the years, but gaskets may be universal. Would have to look in my parts books
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2015 at 8:14pm
thanks i would appreciate that. i havent been able to find anything just for the 344 it list all the engines anywhere i look.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2015 at 10:42pm
Books say; Prior to tractor# 13322 (Buda) Head Gasket - 4349764.
For tractors 13322 and up with 6000 engine the old orange books say the gasket is 4349936. The later yellow books say its 4349883. Just a superseding of numbers I think, same gasket. Included for that same gasket are the 7000 turbo engines.
Maybe someone more knowledgeable than me can chime in and say whether the later gaskets can be used on the Budas.
I have not applied the Fiat Allis prefix to the numbers
Edited by Mactractor - 09 Feb 2015 at 7:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2015 at 11:04pm
i'm calling the budaengine company in the mornign in shreveport. ive called around and everyone says get my kit from them. so ill just send what i got back and order everything there sounds like they can hook me up with everything i need. i was going to transplant the later motor in it but my father bought the whole machine and were going to takle the hd7g transmission after this. We just hate parting out machines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2015 at 6:18am
I have a 7G that had trans issues, I transplanted and now have the old one to tear into to see if can fix it back up. Seals for shifting oil were completely gone and leaking into the case, probably the biggest issue save smoking the clutch packs.
beanking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote beanking Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2015 at 1:05pm
Had this one.  A bit clunky to operate with a not so great accuracy, but for a farm machine, I have no complains. It's perfec.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2015 at 4:28pm
I had bad luck with the Buda engine company. My information was that they purchased Buda and had no idea what they purchased. I tried for over a year to get a head gasket from them but they never delivered it.
I was able to get the rebuild kit including head gasket from Syracuse Crank & Machine (800) 437 3609 Please post if you have any luck with the Buda engine company
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2015 at 2:47pm
guys the buda engine company is a no go they only service buda engines. and can get and sell some parts.I have been calling all over and finally found everything i needed at kwick parts in williamsburg missouri there expertise is allis chalmers and fiat allis. they were able to get and find every part i needed. there great people there and i highly recomend them. thanks again all for your help we are going to start putting things together after all parts arrive and then start another project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2015 at 4:58pm
The HD6 motor is a Buda. Allis Chalmers purchased Buda after having a problem with Detroit Diesel. The Buda motors were improved by AC. Replacing an HD344 with an Allis 7000 turbocharged motor is a good idea.
It looks as if the Buda motor company has not improved with time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2015 at 5:45pm
Did you find out if the head gasket for the thousand series AC engines can be used on the Budas
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2015 at 7:46pm
guys what they told me was there were minor changes as the head being the biggest change. i was told the head gasket will work for all 3 changes in the motor. and that the bottom end block is same. the difference there in bottom end is the buda has the 5 rings on a piston and the newer motors have a 4 ring piston. and liners/sleeves are the same throughout. they sell a conversion gasket set to put a 6000 series top end on your lower short block. this is some of the stuff Greg at kwik parts explained to me. greg and his wife started the company after Cooks closed there stores when old man cook passed. they took there knowledge and are putting it to use helping all us allis people. another good place to call for knowledge is zimmerman tractor in versailes missouri they part out old allis equipment everyday and rebuild or transplant newer motors in them and can help alot. if kwik parts couldnt have helped me zimmerman were going to be converting to a newer style engine for me. thank you all for your assistance with this hd6 so i can bring it back to life. i may have some minor details to ask like torque questions on bolts and so on. but after this project i will be pulling a hd10 w out of the woods where it has sat for 28 years to try and ressurect it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2015 at 7:59am
You can't put a 6000 or 7000 head on a HD344 block without changing the pistons. You can't change the pistons without changing the connecting rods. The HD344 pistons are flat top because the combustion chamber is in the cylinder head. The 6000 and 7000 have dished pistons and the cylinder head is flat. There are deep dish and shallow dish pistons for the 6000 and 7000 motors. You can use either dish style. It was an EPA thing about diesel smoke. The wrist pins in the 6000 and 7000 motors are larger than the HD344. That is why you have to change the connecting rods. Transplanting a 7000 motor is less expensive and it is a better motor especially if you have an early HD344 with crankshaft driven generator and water pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2015 at 1:45pm
thats why i put what he said cause by looking at the motor it sure looks like alot more to change over then what was mentioned. well i must have a late 344 cause my gen is run off belt. anyways i ordered the parts to fix the motor. just going to keep it all the same. and then after the 10 we will see whats wrong with the 7g's tranny. hate to part out good machines when undercarriage is in excellent condition on a machine its hard to tear one down. seems underside is more expensive to get fixed then anything between tracks is.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2015 at 9:27am
AC and Detroit Diesel parted when GM bought TEREX and started building crawlers themselves - 2 companies offering same engine doesn't make for good sales pitch.
Steven25 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steven25 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2017 at 2:46am
Where did you get your engine kit from? I'm having a hard time finding one. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2017 at 7:30am
http://www.agkits.com/
They have the head gasket for $103 They had the engine kit you may have to telephone them
doctorcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2017 at 9:21am
   DMiller, did you ever find a source for the 7G trans seals, the ones in the distribution blocks?
Semper Fi USMC    1958 HD6G, 1959 MF 203 loader, 1960 Case 420B Backhoe, MF 65 Tractor/Loader Diesel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2017 at 12:56pm
Not yet, my old trans sits in the shop still intact. I intend on a winter project to tear it down and take the seals to E&E Hydraulic in Union to see if they can come up with any kind of match.
