hd 6 g serial #
ratchet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ratchet Quote  Post ReplyReply Direct Link To This Post Topic: hd 6 g serial #
    Posted: 19 Jul 2012 at 9:27am
I need assistance identifying a hd6g I just purchased. There is a plaquard on the dash that has hd6g-16378, and on the right rear of the machine stamped hd6g 1637 any help idemtifying this machine would be appreciated, also i have a hd6g 1956 model are the parts interchangable??Confused
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2012 at 12:03pm
Yes must parts are the same in the 2 machines
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2012 at 1:13pm
I suspect you dig a little harder at the rear and that '8' will come up, too close a number on both to not be the same.
ac_sd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_sd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2012 at 4:36pm
That "8" could be a worn off "G" also....... If it has a 344 engine its likely a 1637 s/n, if it has a 6000 engine its likely the higher s/n.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote ratchet Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2012 at 7:28am
Its a 1963 model the higher serial # Thanks for all of the help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2012 at 11:50am
 The HD6G later serie the head motor is different and should have a crossbar betwen the 2 finder and the hydrlic hose are attache on and for changing the stering cluch you need to drain the hydrolic tank and removed the cylinder hoses and crossbar.
