hd 6 g Buda crank
ratchet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ratchet Quote  Post ReplyReply Direct Link To This Post Topic: hd 6 g Buda crank
    Posted: 16 Jul 2012 at 1:20pm
I am in need of a crank for my hd6g casting # 4348425. If anyone knows where i can get one or a source, it would be greatly appreciated.
Dozer View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 3:15pm
I have a HD344 crankshaft that I pulled from my HD6G. It spun #4 rod bearing. I got a quote for reconditioning it at $300. It costs about $100 to ship it. Note that there are surplus 7000 motors on eBay. The AC 7000 motor is the generation after the HD344 with a turbocharger. If you can afford the shipping, the 7000 motor is the better investment. If you are interested in my crank send a PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote ratchet Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2012 at 6:46am
Dozer :thanks for the help! I Pm ed you on the crank..Is the 7000 motor the same block? Will it bolt directly up and fit in the frame rails on the machine? what are the differences? Thanks for the assistance!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2012 at 7:31am
The HD344 AC 6000 and AC 7000 motor are the same motor. The 6000 & 7000 motor have a different cylinder head, pistons and connecting rods than the HD344. They are interchangable so long as all the items are replaced. The 7000 motor is the turbocharged version of the 6000 motor. The newer motors drive the waterpump and generator from the injector pump rather than the crankshaft. There are many other changes but the newer motors will bolt up where an HD344 was.
