hd 6 b 6spline
dragboat1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dragboat1 Quote  Post ReplyReply Direct Link To This Post Topic: hd 6 b 6spline
    Posted: 05 Oct 2015 at 7:43am
does anyone have a photo of the sprocket and nut separately . also does sprocket fit tight on axel mine I can slide on by hand. thank for your tme
Edited by dragboat1 - 05 Oct 2015 at 7:54am
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2015 at 7:59am
sprocket should slide on by hand until it seats on the tapered splines
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2015 at 9:24am
once axle is onto spline the nut drives it home onto the taper - it should not be loose or wobble when placed by hand and then then should feel snug
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2015 at 7:39pm
hopefully this pic of the axle went through. not sure what else you may need
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2015 at 7:43pm
hub pic
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2015 at 4:28am
dadsdozerhd5b
Have a look backwards from here for what Killdozer is proposing for a wrecked sprocket spline - if you're near a GOOD machine shop I'd say!
http://www.redpowermagazine.com/forums/topic/83591-1952-atc-terratrac-gt30-track-loader-roller-repair/page-22
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2015 at 8:57am
wow.. looking back, definitely a labor of love
Edited by CAL(KS) - 07 Oct 2015 at 11:05am
