HD 5 steering clutch
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Topic: HD 5 steering clutch
    Posted: 04 Feb 2020 at 3:18pm
Have all bolts out of the clutch on each side and the pins out of the brake band. Book says to lift out assembly, but can't get it to move. clutch was full of a mouse nest and would not release. Any thing I am missing? Ideas?
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 3:25pm
The stering cluch flanges have a lip on and you need 1/8 inch each side from the brake drum
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 4:01pm
They 'Should' Slide away from the clutch pack on splines, might need a little coercion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 5:47pm
1/8 on each side is what I was thinking. But will not  move, need some heavy duty coercion I guess.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 5:58pm
Ah, mouse piss, nature's gorilla glue...Wink
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 9:26pm
Call Tom.    LOL Leon
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2020 at 5:06am
If you could leaved the stering cluch lever engaged with pression and knocking on side flange it't could help
This page was generated in 0.529 seconds.
