HD 5 Main Clutch |
BFC
Topic: HD 5 Main ClutchPosted: 05 Oct 2024 at 6:39pm |
I recently bought a Hd 5 crawler. I'm looking for supplier of clutch parts a yoke # 053925.
Looking for information on removing the yoke. Can it be done by leaving the housing in place or would you have to remove the part from the crawler? |
gemdozer
Thanks(1)
Posted: 05 Oct 2024 at 8:32pm |
I am not sure if you can removed the yoke with out removing the cluch belhousing and master cluch ,the yoke have a short shaft each side with key way
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42261 |
Thanks(1)
Posted: 06 Oct 2024 at 4:06pm |
Remove bell housing , remove full clutch assembly , disassemble on bench and find the parts you need . I ended up turning the brass sleeve myself to replace worn one in my machine . Also check pins on the over-center linkages and the arms themselves for wear
BFC
Posted: 06 Oct 2024 at 5:53pm |
Thankyou for quick response, on my question.
Coke-in-MN
Thanks(1)
Posted: 07 Oct 2024 at 6:57pm |
The clutch friction material also needs to be checked and rivets holding it , the disc if it has dampening springs also need checking . I replaced a couple discs ad last time I went to bi-metallic disc . Same as the HD11 steering clutches I used rather than fiber discs .
It may be necessary also to check flywheel and friction face of clutch to see if they need resurfacing . Replace the bearing in the crankshaft with new sealed bearing , making sure crankshaft wick fitting is plugged . Original pilot bearing was lubed from drilled hole in crank, by using sealed bearing no oil is introduced into clutch housing area . |
gemdozer
Thanks(1)
Posted: 08 Oct 2024 at 10:20am |
If you removed the belhousing and cluch assambly you need to removed the cluch bolts first
