HD 4 ?
Matt Tallant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Topic: HD 4 ?
    Posted: 10 Nov 2012 at 9:18pm
Looking at a HD4.Says it is fine in reverse but slow forward.Any ideas?TIA,Matt
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2012 at 4:30am
skipping clutches , worn clutch-pack
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2012 at 9:15am
Is that a costly fix?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2012 at 4:29pm
It involves splitting the tractor , it could be as simple as low hyd pressure or as bad as complete burned out clutch pack .
 Depending on what machine is selling for and how good everything else is depends on what the repair is worth . For if track is bad and sprockets worn - you will have a parts machine that is a downer rather than a good running machine.
 My HD4 became a extra when I bought a skid loader and my HD5G became the workhorse as it held up better and less problems both in repair and finding parts IF needed .
This page was generated in 0.305 seconds.
