Hd 3 Hd 4 starter will they interchange?
Brian S(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Topic: Hd 3 Hd 4 starter will they interchange?
    Posted: 23 Nov 2009 at 9:01pm
Will an hd4 starter fit on a HD 3? Thanks brian S
Kipn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kipn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 10:06am
I don't think so. Different motors. Also built in different decades. Could be wrong, as the tracks are the same.
John(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 10:43am
Part number for the HD4 is 245331 (Delco 1107589).  If you have the parts book on the HD3 you can compare numbers.  I don't have the HD3 part numbers.
Learn something every day!
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 5:35pm
HD 4 uses a center bearing in the starter housing behind the starter drive. I found a White Truck starter that would interchange all internal parts (fields and armiture and bearing plate, end plate) but front housing had to be the HD4 (AC 2200 engine)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 3:04am
Thanks for the info. When I try to start the HD3 it will turn over then I hear a slamming noice which sounds likethe starter is being kicked back out of the ring gear? Have a motor for an HD4 complete with starter and was just wondering.
Edited by Brian S(NY) - 25 Nov 2009 at 3:05am
