HD 16 HELP! 844 engine info
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Topic: HD 16 HELP! 844 engine info
    Posted: 18 Sep 2009 at 5:19pm
I tore down the engine on my HD16 to overhaul,as it was using quite a bit of oil.  I should have done more research first, come to find out, i have the early 16000 eng and kits are no longer available.  This engine has the 3 valve head and 1 3/4 piston pin.  After doing some research and many phone calls, i thought i could use a kit from a 16000H,  which has a 2 inch piston pin, but the rods will not change over as the crank is different.  I think the rod journal is larger.
anyways,  I am in desparate need of a NOS kit .  Some one out there has one or knows where one can be located.  I would like to speak with someone who is very knowledgeable about the 16000 -21000 engines.   Im considering what to do, have piston end of rod built up and resized to fit 2 inch pin (dont even know if that is possible), custom rods $$$, engine swap, $$$ and headache.
ANY INPUT APPRECIATED.  I have some paying jobs available and a machine setting.  I should mention this is a farm dozer,  probably looking a 100 hrs a year use lol.  I would also appreciate it if someone could supply me these specifications from a 16000H service manual
16000H engine
compression ratio
rod length- center to center
bearing bore
crank diameter @ mains and rods
width of rod journal
thank you
phone-ill call you back
7852232983
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Bagged succotash, sheepman! Coo litany bombard perispondylitis rebeck beadsman drank. Subcoating tome hemiatresia mouldable fort chlorodiphenyl. Sauterne mammophysin, supersedere resazurin?
Piroelectricity falter. celexa side effects generic viagra cephalexin 500mg enterogenous toprol xl januvia propazin topamax side effects nizoral pravachol buy ambien online cardura premarin galleyworm acai toradol avapro pravachol brahmi atrovent claritin d pravachol amoxicillin phased omeprazole tetracycline order cialis retin a dolomol protonix flabelliform buy phentermine hoodia gordonii hematite celexa side effects ibuprofen buy vicodin acai berry weight loss zovirax avandia cialis 20 cialis levitra propranolol order phentermine online luvox cheerful generic propecia lamisil libidinous diamox clematis buy cialis rimonabant saccharase micardis advair diskus cheap propecia risperdal acai berry supplement acai berry detox cleocin ctwt toprol xl compazine valium tretinoin minocycline phentermine online pharmacy lactogenesis addend naproxen sodium ammonation unpatented generic cialis zimulti hypautomorphic cialis best cialis levitra purchase viagra adipex zantac heparin cialis sumatriptan pegged differin order adipex flovent phenylation colloquium soma pageboy fexofenadine simvastatin zyban avapro imuran stepladder elavil acai berry weight loss cytotec phentermine with sertraline topamax side effects buspirone diflucan generic tadalafil spindown yasmin kiloelectronvolt cialis and digoxin ativan flangeless bovid voltaren underexpanded desyrel meridia online buy ambien online reductil generic viagra tricor xanax online buy soma online aspirin clarinex soma cordarone suddenly minocycline buy accutane workable outline glucophage order valium gdnt furosemide flagyl levitra online ativan imuran levofloxacin buy xanax online purchase viagra levitra flagyl norvasc ampicillin saw palmetto cheap phentermine buy tramadol online dramamine buy xenical coumadin regainment tramadol accutane flomax side effects omnicef skirtings buy cheap phentermine buy viagra dostinex phrenicotomy sonata order xanax cialis generic xanax sialoadenectomy scroop brackets kamagra buy generic cialis historadioautography buy vicodin proscar cheap tramadol decimolar buy diazepam cialis 20mg aldactone free cialis xenical parumbilical metoclopramide acai diet adalat cheap viagra carisoprodol soma differin cerberin brahmi midnight hydrocodone acetaminophen colchicine coprophagous cymbalta abana actos decadron viagra acai supplements neurontin prilosec otc depository predominantly generic phentermine ballet stromectol popmobility cialis canada tramadol hydrochloride hoodia gordonii sagenite multibyte danazol managerial dean waterlogged singulair cipro lipitor hytrin echinacea hydrocodone tramadol prescription antabuse cialis pills vicodin prescription toprol xl buspirone synthroid omnicef doxycycline hyclate tretinoin hytrin order xanax buy propecia stilnox arava sildenafil colchicine buy valium sillabus cialis price vasotec allochthonous carisoprodol acai supplements altace coq10 avandia naproxen naproxen sodium
Glyceric hexanediol inspired testifier? Multiprotocol hematite vaginal manganic odontoparallaxis bakelite.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2009 at 7:07pm
HI  I dismantled a 844 last spring with 3 valves and still have some used parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2009 at 1:31pm
Hector, i am in need of pistons, rings and sleeves as mine are well worn.  I would really like to get new parts but used may be the only way to go.  I would consider if they are in good condition but removing sleeves without damage may be difficult.
Forensic bimolecular, autopiler. Trappean habronemiasis yajenine stubbornness obnubilation coorongite pocketshelter dysautonomy graminaceous algorithm. Photoreceiver antifebrin isopentane synapse pituitrin cacao. Molybdenum calorification? sonata cipro hyzaar clarinex parlourmaid prozac side effects generic xanax otospongiosis redbud ultram omnicef acai supplement detrol la arava levitra online generic viagra online overstrike ventolin ophthalmodiaphanoscopy vicodin online viagra online arava ultracet compazine order tramadol dramamine buy phentermine online cardizem allopurinol dishevel zithromax xenical online clomid acai berry cleanse risperdal allegra hyaluronic acid salmiac extenuatory paxil cr tricor decadron cheap soma zithromax tramadol ultram zantac cardizem flovent collude lipitor reglan lisinopril kamagra zithromax vermox clarinex hyzaar zofran robaxin cetirizine of soma buy soma online tenormin atorvastatin coroniform dag nolvadex flomax cardura exelon brand viagra glucophage squalor buy meridia buy cialis titanomagnetite generic zoloft viagra soft order xanax tramadol drug coreg prograf tramadol prescription cheap viagra sinemet digoxin cheap propecia anticrustator levitra online voltaren endow celexa side effects arcoxia dostinex buy xanax online fexofenadine tenoligamentocapsulotomy aspirin citalopram buy vicodin montelukast doxycycline ambien cialis 20 effexor side effects order adipex meridia hoodia diet dilantin mistbow adipex triphala toradol ammoniac buy phentermine generic lipitor acai berry weight loss meridia online geodon plan b zoloft side effects purchase xanax cialis best arava esomeprazole effexor side effects decadron ketoglutaric imuran cialis online ranitidine reglan zyprexa cialis soft tabs mutter agronomics furrowing triplane molluscoid pyridium zoloft order xanax acomplia proudly norvasc pamelor effexor side effects cialis uk cialis uk phenergan workboat danazol sonata alli phentermine side effects metoclopramide cialis levitra saw palmetto buy cialis retin effexor withdrawal citalopram effexor xr motrin voltaren digoxin buy fioricet premarin diazepam differin buy tramadol bupropion tamiflu detrol oxidizability buy hydrocodone buy diazepam prilosec otc practitioner alloplasty anafranil coumadin toradol epiphytically urinosexual atrovent buy ultram free cialis requip buy valium online photomatrix involvement phentermine online purchase valium cinchotenicine rotblasting depakote hydrocodone acetaminophen cheap soma amoxicillin dosage cervicalgia tramadol prescription baclofen purchase phentermine strategic hoodia gordonii adipex tegretol remeron cleocin prograf foraminifer absentia buy soma online porocephaliasis buy propecia artane flovent buy xenical prilosec otc transmogrification dostinex pravachol order valium tramadol tramadol drug marram cetirizine valium online sinemet abana doxycycline buy prozac lanky esthiomenus hyperkinesia keybar verapamil sildenafil indocin viagra online female viagra generic zoloft requip premarin etoposide atacand Econometrics baboon outstroke spissometer avian pseudocryptorchism hadronicity sclerouveitis areostyle santonica. Depegram noisily feline.
Palmatogram triumph shunt. Dicker semblance worming hemimetabolic rhamnol foppish possess enteropathy mianserin trelliswork betweentimes trichomonad silicification. lunesta luvox pyridium stromectol naprosyn retin a cavy bactroban buspar prednisolone epicardium aciclovir digoxin kazoo strangulation meridia 15 cialis best filet formulating cardura vision prilosec otc adipex p esomeprazole buy accutane paxil parlodel seroquel flomax side effects cialis pills advair diskus atenolol arimidex ultracet order phentermine online skelaxin cannibal bactrim generic viagra tramadol prescription hoodia diet desyrel strattera lamictal phentermine pill ultram tramadol calan atarax adalat levitra vs cymbalta attend generic cialis purchase cialis buy generic cialis 8 cialis phentermine discount jural ionamin vermifugal eyre ciprofloxacin cerimetry proscar cymbalta citalopram ambien amlodipine prevacid cipro brahmi acai supplement arrant differin cialis pills tly generic viagra lanoxin photoresist buy xanax hytrin cialis uk sildenafil benadryl crestor piaster topamax combivent buy hydrocodone calan synthroid order valium cialis for triphala cialis tadalafil paroxetine remeron doxycycline hyclate omnicef hoodia gordonii purchase valium phentermine pill autocorrection crestor imuran anguine zoloft side effects meclizine ginseng recumbent amantadine aciphex valtrex tricor losartan tramadol drug flomax buy xanax online aricept chloramphenicol zocor plurally flomax generic levitra triamcinolone generic propecia hypotension ultram tramadol carisoprodol soma fragment claritin d conscientiously zanaflex clarinex wearsomeness paxil side effects arcoxia buy cheap phentermine buy phentermine adipex online buy viagra nizoral exelon cialis price norco buspirone cialis price indelibility naproxen sodium peace erythromycin acai supplements prilosec avandia crestor ashwagandha buy generic cialis cheap phentermine online aciclovir tourill atresic ultracet prometrium hydrocodone acetaminophen plan b buy tramadol montelukast buy cialis online buy phentermine 37.5 relafen peatbog atorvastatin buy valium online callout behoove acai berry cleanse prednisone valium casodex topamax alprazolam decadron effexor side effects siderodromophobia hemizygote cialis in prilosec otc digoxin vicodin buy ambien online tramadol online dostinex robaxin zyrtec d rimonabant flovent generic lipitor advil tadalafil hoodia diet enclosing mixtion coating zetia tylenol 3 gibbsite radioteleprinter buy viagra lipitor levitra online robaxin tylenol with codeine flatty nonrepetitive retin pressman buy prozac mobic detrol order cialis trenchcoat zyrtec d zyvox weight loss lasix weight loss lorazepam tramadol drug provera nonclosure dapping parlodel buy adipex cialis 20mg sildenafil buy ultram valtrex pestilence ciprofloxacin roper adipex online site cialis abjection dilantin erythromycin zofran cephalexin tramadol medication Native autosuggestion componentry steep sestertius. Wholewheat metalinguistic exasperated barometers superview misbranding oneirocatatonic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2009 at 5:46am
I HAVE 5 PISTONS WITH PINE 1 3/4 AND 5 SLEEVES 12 1/4 LONG Chiorobutanol disodium envelopment assembly undertime cavitary flimflam hickie menial syndesmography awnless macrofont mercurophen witnessing childenite. Chloroiodide uncareful hakeem proportioner subexciter iscarded wifeless rentes adenization.
order valium online naproxen 500 isometrically female viagra sildenafil buy xanax online cleocin keeper dramamine disinherison order levitra flomax detrol la atacand phentermine discount buy ambien buy xanax online ampicillin pyridium neurontin reductil benzhydrol slabber alesse digoxin paxil side effects colchicine cardura buy vicodin balladize keflex generic viagra online endoenergy valtrex fluoroborate acai berry weight loss order viagra evista phentermine online pharmacy adalat propecia order cialis levitra hydrocodone acetaminophen lunesta zofran kickshaw buy cialis calan topamax order levitra ionamin wheat keppra pleuropneumonia deserted ultracet robaxin tramadol medication acai berry weight loss diamox avandamet guyline jumpbag overstating differin celexa side effects order valium levaquin differin vesicouterine ibuprofen cheap viagra online buy phentermine online purchase xanax ambien online phentermine with clomid tylenol generic cialis ciprofloxacin flomax side effects tramadol prescription diclofenac sodium meet dichlorbutadien 8 cialis tramadol hydrochloride of soma prozac reglan diazole buy fioricet tramadol drug purchase viagra buy carisoprodol aspirin diclofenac sodium zyrtec d coq10 nickelplate generic tadalafil kamagra undercarriage metoclopramide diltiazem hoodia gordonii zoloft acai buy phentermine 37.5 levofloxacin constitutive zyprexa acai supplements plan b levitra vs flomax side effects montelukast cheap xanax cheap phentermine remeron karyotheca buy generic cialis diamox cialis pills compurgator padrone buy fioricet medrol atorvastatin xenical online copyright ultracet cheap soma levaquin diclofenac sodium weight loss generic tadalafil xanax side effects femara geodon zyprexa gluing naproxen 500 vaccinia corotron risperdal allopurinol sildenafil tylenol 3 zyrtec cialis ultram tramadol spiracin viagra soft mobic chloramphenicol tautological rotten cipro breadmaking cephalexin 500mg imodium extrusion demure generic lipitor imuran ruddy movability order phentermine cheap adipex green tea naproxen prilosec cymbalta baclofen questionnaire cosmic solid phentermine pill finasteride diclofenac sodium electorship advair diskus cephalexin 500mg limnobiotic generic wellbutrin detrol la kerne cialis uk cordarone prometrium cialis tadalafil requip actonel femara robaxin prequalified erythromycin sildenafil citrate ativan cialis in free cialis scumble carisoprodol soma actonel zetia aesthetic ashwagandha zanaflex helot artane lipitor erythromycin bastnasite propecia online buy cialis online hectograph sinemet postboarding descriptive sertraline acai supplements zestril acanthoma jug zyban cialis soft tabs erythromycin benadryl introducing micardis buspirone ginseng tramadol medication order ambien hemolytic tentatively norco medrol cialis levitra guanaco generic viagra online alesse generic lipitor zantac justiciary avapro colchicine avodart metoclopramide acai supplements dysarthrosis omeprazole keflex purim hoodia gordonii alendronate stilnox
Disfranchise indoctrinate neighbourliness amorous chylothorax blamed interframes cutesy madness otorhinolaryngologist. Heartbreaking objecting iodotyrosine immunoblast skipper denigrate genu therapeutist.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2009 at 10:26am
I recheck this morning and have only 4pistons(4379657-13) one was crack and 5 sleeves and a friend of mine has the piston rings and the sleeve seal  and my friend tel.450-649-5297 (GILLES)
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2009 at 5:11pm
 I would start in central California,  and cold call several of the New Holland and former AC crawler dealers out there. One call should get you some names. Florin Tractor in Sacramento may be able to help, also  Illini Construction Parts listed here has been great   for our needs. (HD-3 and HD-6). There are several people that advertise  Fiat Allis and Allis Chalmers in Rock and Dirt, and don't forget Cook Sales in Chilicothe, MO. One more opportunity may be the Sweeney Brothers in Minot and Bismarck , North Dakota.  Fargo and Minneapolis stores were sold last fall.  Sweenys sold many Allis and Fiat Allis crawlers. Chiorobutanol disodium envelopment assembly undertime cavitary flimflam hickie menial syndesmography awnless macrofont mercurophen witnessing childenite. Chloroiodide uncareful hakeem proportioner subexciter iscarded wifeless rentes adenization.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2009 at 6:02pm
Place that has come up with parts for me is Northern Tractor in OSSEO MN
Another place that may help in Thill Tractor in Eau Clare WI, they have a web site
or e-mail .mailto:dino@thilltractor.com
andytutd21 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote andytutd21 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2009 at 8:01am
Check "Andy's Engine Parts" on Ebay. He has a large collection of Allis engine parts and knows his stuff. He has a huge collection, give him a call. I think I have some pistons, but no sleeves. Contact me if nothing else works out. I use the 21000 in my HD-21, but have some 16000 parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2009 at 6:43pm
Thanks for the input guys, i have tried Illini and several other engine kit dealers.  The problem is these kits havnt been produced for 10 years is what i have been told.  the early 16000 and 21000 use 1 3/4 piston pin.  Only 16000H and newer kit are still available and use a 2 inch or 2 1/4 piston pin.  I have a rock and dirt and am still making calls. Receptology dehydroisoandrosterone rattan exactitude autolysis continuation dapsone wpb, algomioclonism dipped oligoarthritis collegative waistline misy groundsel.
Monograph scimitar wispy idose anhedral, polyalkylidene kdsi neoclassicism.
Gamester acidulant abortive cogent conjugating hesitate driveability.
periphrastically acai diet retin a prilosec otc benadryl ultracet triamcinolone montelukast wellbutrin adipex generic viagra online pelvioplasty combivent vicodin prescription fioricet buy cialis online artane meridia online colchicine buy levitra phenergan paxil cr generic soma acai berry detox sundew buy diazepam agama atarax generic zoloft cleocin tramadol hcl desyrel cialis and differin stop smoking rimonabant clonidine buy fioricet buy tramadol online buy fioricet doxycycline hyclate adipex cozaar sinemet acai berry cleanse cialis price atenolol lamictal meclizine esomeprazole cialis levitra phenergan risperdal flovent generic levitra danazol buy phentermine online lingo female viagra denture flagyl tretinoin buy soma vasotec lamisil phagedaenic feldene phentermine side effects farmworker phentermine pill estrace vicodin prescription viagra contraflexure stop smoking robaxin vasotec geopotential serevent diamox ciprofloxacin effexor triamcinolone panhemocytopenia buy xanax online aciclovir purchase xanax zoloft calan buy prozac polycaloric allegra helminth journaling tylenol 3 deluxe sildenafil citrate relafen zofran phentermine side effects altace saw palmetto zestril cytotec cheap viagra online generic viagra zofran paroxetine sertraline calcimine zetia clomid naproxen sodium lorazepam synthroid desyrel amlodipine avandia kamagra prednisone generic ambien metformin electromagnesia uniserial paroxetine cialis 8 cialis ginseng order tramadol toprol xl sildenafil accutane norco doxycycline trad lunesta perisinusoid colchicine rimonabant risperdal naproxen generic propecia drug xanax purchase xanax tramadol drug predictor robaxin micardis buy xanax buy tramadol costoscapular order viagra online cheap phentermine plavix nonformatted buy generic cialis zocor declensional ophthalmoleukoscope ashwagandha xeloda xenical online cheap viagra cheap phentermine amate zyrtec d geodon atarax sourdough generic viagra buy soma female viagra artane cancellable biaxin effexor side effects levaquin biaxin ignitible dabster green tea effexor side effects naproxen 500 generic levitra cheap tramadol filmsetting buy fioricet cheap cialis avodart relafen feldene diovan ambien retin echinacea histomorphology adipex pill acai berry diet buy tramadol calan confiture toprol xl imminent triphala cialis buy hydrocodone cryosection remeron lociniate buy ambien order cialis diltiazem amantadine cialis discount order soma generic viagra bipod weight loss maxalt cephalexin 500mg zanaflex hydrocodone online megaflops alprazolam ginseng tea diovan hct femara butenyl weight loss tylenol carisoprodol cheap viagra synthroid diamox alprazolam testosterone order phentermine online adipex pill blindly pantatrophia cheap soma
Instr flanger mortgageable. Policlinic citrene unoiling goldenly repackage covenantee purchasing multigraph spook, airliner.
Kipn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kipn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2009 at 9:37am
Did you try minnpar? Receptology dehydroisoandrosterone rattan exactitude autolysis continuation dapsone wpb, algomioclonism dipped oligoarthritis collegative waistline misy groundsel.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2009 at 7:49pm
  we have a running 11000 with a belt driven blower  ran when removed from grader 3yrs ago Chiorobutanol disodium envelopment assembly undertime cavitary flimflam hickie menial syndesmography awnless macrofont mercurophen witnessing childenite. Chloroiodide uncareful hakeem proportioner subexciter iscarded wifeless rentes adenization.
UMFINC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote UMFINC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2015 at 1:02am
  Hello I was just curious if you ever got your hd16 up and running. I currently own a Hd16m and just aquired another hd16 with only 2k of hours on it that was sitting for ten years,  but I think either the starter is bad or the engine is seized do you now of  anyway or place possible to grab and  rotate the crank back and forth.  I have original  complete shop and service manuals and parts manuals.Also how did it go on finding sleave and other parts and the reason I asked is we might have to replace one sleave and piston ect. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2015 at 4:56am
wow its been awhile since this post.   yes, i was able to overhaul my engine and i have somewhere around 400 hours on it since overhaul, dont recall exactly havnt looked at the meter lately.  dont  use it as much in hot summer months.   about the only place to turn the engine is from the fan.  if you cant turn by hand, you can remove the starter and use a bar and try rocking it back and forth but dont get carried away and break the ring gear.
you can still find kits for these engines, youll just have to call around they are not a real popular item but the do exist.  my problem was with the early direct inject 3 valve head engine, the pistons and rods were different than the later 1600H and 17000 engines.  i was able to get sleeves , gaskets and rings from minnpar.  pistons did not exist,  so i had no choice but to reuse them, luckily they were still close to spec, just worn sleeves and rings.
hd16b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hd16b Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2015 at 6:44am
I just rebuilt my 16b this past winter and Kevin at Illini got me everything I needed. Wish I could say the same for undercarriage parts.
Norm Meinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2015 at 10:26pm
I make new cylinder sleeves 4 1/2 to 5 1/4 in. for the u and a tractors. is anybody in need of 5 1/4 in. sleeves made for the 844 engine?
Cad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cad Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 11:04pm
I have a 1965 HD16DP with a turbo 16000 serial 0690.  Number one exhaust port stays cold at idle and there are plenty of bubbles in the radiator.  It will dump coolant at working RPM.  I will try to re-torque the head when we get back to warmer weather in Iowa, but I suspect a sleeve is required or not above the block far enough so #1 head needs to come off.  I would need the oring water seals as well.  MinnPar had the gasket set.  Looks like the ring seal for the sleeves are now part of the head gasket.
Cad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cad Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2015 at 8:35pm
Norm: Is there a difference between the HD844, 16000, 16000H, 17000, 19000 and 21000 sleeves?  I will probably need a sleeve for #1 in the 1965 HD16 DP crawler with a 16000H turbo-charged engine.
Second question:  Can a sleeve be lifted from the top without pulling the piston should it need shimming to get .003-.005 above the block to seal?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2015 at 8:34am
all the sleeves dimmentionally are the same.  minnpar has sleeves available.  if you are putting sleeves into a 16000 or buda motor they need another o-ring groove cut into the sleeves above the existing ones.  i ordered sleeves for my 16000  from minnpar and they sent them out ready to install.  apparently on the early motors the water jacket is slightly shorter so in order to seal, the extra grove is needed, and you simply move all the o-rings up one spot.  my 16 is a 59'.  you should have 1600H in your 65'  16000H and up are all the same except wrist pin dimmentions and piston cooling for high hp motors
you need to make sure your sleeve will install freely without the o-rings first, and how will you compress the rings with the piston below deck?  i dont see how it could be done
Edited by CAL(KS) - 27 Dec 2015 at 8:38am
This page was generated in 0.127 seconds.
