Hd 11s clutch disengaged but keeps moving
JW Reeves View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW Reeves Quote  Post ReplyReply Direct Link To This Post Topic: Hd 11s clutch disengaged but keeps moving
    Posted: 03 Apr 2025 at 9:38pm
Hello everyone i fired up the hdll after a long winter to push some dirt and after she warmed up a bit. The machine didn't want to stop after releasing the clutch. I pushed it forward really hard to engage the clutch break to where it started smoking on me. So it wouldn't stop i then idled it down and pushed dirt until it bogged down the motor enough to quit. After getting it back into neutral i started it up again and got it back into gear and started pushing again and released the clutch and it was doing the same thing kept on going.   Any ideas on what might be causing this? Thanks
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 2 minutes ago at 6:23am
Sounds as if your main clutch disc is rusted/stuck to the flywheel surface. You can either keep working the tractor with the clutch released hoping it breaks free, or replace the clutch.
Power on, power off in short and quick succession sometimes has luck where you are "shocking" the driveline.
That's All Folks!
