HD 11
everett048 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Topic: HD 11
    Posted: 02 Jun 2018 at 2:31pm
Guys any idea where to get a HD 11 motor rebuild kit fitted with a buda motor.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2018 at 10:27pm
Reliance makes the kit, but you can’t get the main bearings. Part number looks like a RP915157. It’s about a $3000 kit.
Edited by 7060 - 02 Jun 2018 at 10:29pm
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2018 at 3:24am
You might have a read over at Red Power where Reliance kits aren't in the best of flavour - e.g.
And there was one on rebuilding a "360" IIRC
Found it
https://www.redpowermagazine.com/forums/topic/110209-company-with-best-d361-engine-rebuild-kit-and-other-parts/
It seems that the search function on the site doesn't work so well.  Usual suggestion is to use your favourite search engine
It seemed when I was chasing things for an early AC 45 grader that there were more parts available for the 10000 and up engines.  IIRC then you had trouble getting the one-piece thrust and main shells that the early engines  used
You might even land a complete one of those later engines for an upgrade
Edited by Ian Beale - 03 Jun 2018 at 3:31am
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2018 at 7:51am
I sell reliance kits, and have never had a problem with their stuff. Everything looks quality and their customer service is great as well. They may be better now than before I don’t know, I have just been dealing with them for 5 years or so.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2018 at 8:34am
im surprised they would still have the flat top pistons for buda motor.  do they offer the direct inject cup pistons also?   one could conclude that you can get them for 344/ 6000 since its just 2 less cylinders
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2018 at 4:13pm
There are a few more comments on that Red Power thread
Might be that there was "Reliance before" and "Reliance after"
