hd 11 fuel bleed
mattjones View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattjones Quote  Post ReplyReply Direct Link To This Post Topic: hd 11 fuel bleed
    Posted: 17 Sep 2013 at 2:21pm
any advice on priming the fuel system on a 1975 hd 11,ran out of fuel now cant get it to the injectors,any help would be much appreciated
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2013 at 5:25pm
Cut a chunk out of an old inner tube, hose clamp it around the fuel fill hole, and add air pressure to the tank.  (Don't overdo it- you'll blow the filters off)
If you can't do that, shut off the fuel return line at the tank and crank it over with the injector lines loose.  If you can build pressure in the fuel return, then let it go, it will help bleed fuel out of the pump.  If it is a Bosch pump, it can be troublesome to bleed out.  1975 should have a Roosa Master pump though- and hand primer.
Eric Rollin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric Rollin Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2014 at 10:04pm
Get a a couple of fully charged batteries and keep cranking holding the gas pedal WOT. Loosen the injectors fuel line nuts and crank until fuel streams out consistently (air bubble free).
Ensure you have used the manual hand primer on lift pump (if equipped) to purge the low pressure side first loosening fitting prior to high pressure injector pump and at filters one at time starting at low points and moving through system until no air is apparent
Gargoyle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gargoyle Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2014 at 1:56pm
I'm guessing that you know more about dozers than I do, but on my 11E, my local guru didn't know the trick  that I found. I'm not saying this process is correct, but it works for me every time.
I open the bleeder on the primary filter and gravity takes over. When fuel oozes out the top, I close it off. I open the bleeder on the secondary, but I have to crank the motor. I crank until fuels oozes out the top of the secondary. I replace the bleeder and that's it.
My guru said that gravity would allow both filters to bleed of the air. I waited and waited and the secondary would not bleed off. So cranking is the trick for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2014 at 2:10pm
Gargoyle, that is due to the restriction of the transfer pump after the primary filter, have to crank it to get the pump to aid flow.
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2014 at 7:22pm
also correct place to bleed on the pump is the nut on the top centre where the fuel injection pipes leave. On American bosch psb pumps
tits tyres and tracks
they all cost you money
This page was generated in 0.162 seconds.
