HD 11 EP torque converter repair
dragboat1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dragboat1 Quote  Post ReplyReply Direct Link To This Post Topic: HD 11 EP torque converter repair
    Posted: 29 Apr 2018 at 10:34am
Have a hd 11 ep will go and the fills like it locking up can back it up and it seems to go for a little ways them bindes up again track is not binding up just not sure. And should drive shaft from torque housing spin all the time. any help will be greatly appreciated.
gemdozer View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2018 at 2:03pm
The EP should have wet brake and cluch and your streaner should be clogged
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 9:08pm
If the drive shaft under your feet is turning, but machine is not moving, either the transmission clutches are slipping or (less likely) the steering clutches.  Does it make any difference if the machine is warm or cold?  Watch the transmission pressure gauge on the dash while problem occurs- does it stay up?  For sure check your fluid levels, and you can also disengage one steering clutch at a time to eliminate problems in steering clutches and final drives.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2018 at 7:18pm
Power shift on my 7G works similar, the clutches engage from a torque driven external pump, that goes south and the drive shaft spins nothing drives. Need to get pressures checked and see what occurs when shift in and out of gear.
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2018 at 6:44am
My 16 D.C. does not have a problem however I do not have a transmission pressure gauge on my tractor. If I wanted to add one, where would I plumb it to?
This page was generated in 0.127 seconds.
