HD 11 EP torque converter repair |
dragboat1
Topic: HD 11 EP torque converter repairPosted: 29 Apr 2018 at 10:34am |
Have a hd 11 ep will go and the fills like it locking up can back it up and it seems to go for a little ways them bindes up again track is not binding up just not sure. And should drive shaft from torque housing spin all the time. any help will be greatly appreciated.
gemdozer
Thanks(1)
Posted: 29 Apr 2018 at 2:03pm |
The EP should have wet brake and cluch and your streaner should be clogged
Lazyts
Posted: 30 Apr 2018 at 9:08pm |
If the drive shaft under your feet is turning, but machine is not moving, either the transmission clutches are slipping or (less likely) the steering clutches. Does it make any difference if the machine is warm or cold? Watch the transmission pressure gauge on the dash while problem occurs- does it stay up? For sure check your fluid levels, and you can also disengage one steering clutch at a time to eliminate problems in steering clutches and final drives.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35650 |
Posted: 01 May 2018 at 7:18pm |
Power shift on my 7G works similar, the clutches engage from a torque driven external pump, that goes south and the drive shaft spins nothing drives. Need to get pressures checked and see what occurs when shift in and out of gear.
jerbob
Posted: 02 May 2018 at 6:44am |
My 16 D.C. does not have a problem however I do not have a transmission pressure gauge on my tractor. If I wanted to add one, where would I plumb it to?
