HB212 Garden Tractor
reedski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote reedski Quote  Post ReplyReply Direct Link To This Post Topic: HB212 Garden Tractor
    Posted: 21 Aug 2015 at 8:38pm
I need ideas on problem with my HB212, I am a retired engineer and have exhusted my ideas.
My tractor is super sensetive as the hydro control is moved. When the unit moves it has a periodic "surge" the rpms remain the same. I can take it out on the street af full throttle and speed, it works without surging. Problem has become progressivly worse over several years
I have:
Checked for leaks
Checked and replaced belts
Eliminated carburation probs
Replaced the Hydro filter
Verified positraction adjustment
Anybody had this prob? Things to try ?
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2015 at 4:16am
air in the system? pump going out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2015 at 5:28pm
was thinking about this all last night...bet you have some linkage that's worn a bit!
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2015 at 10:29pm
Have you checked the bolts that connect the bevel gear box to the frame tunnel? If they are getting loose you could have intermittent belt slip.
