Hay Equipment
Message Reverse Sort Order
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Topic: Hay Equipment
    Posted: 27 Dec 2019 at 11:29am
I first bought an old Hesston 1090 and it imploded after a year.  The reel shaft broke and some of the reel got caught in the conditioning rollers.  Total loss.  I bought an old ford hay rake and it fell apart after one season.  I bought an old Allis rake and it broke after 20 acres.   I basically have not had much luck buying cheap hay equipment.  I was lucky that I could borrow some equipment after these breakdowns to finish the job.  So, I gave up and went after better equipment.
I bought a New Holland 256 dolly wheel rake for $1,500.  Nice rake although, I need a v-rake to go faster.  Purchased a Kuhn 28GMD disc mower (does not have conditioning rollers).  I felt like the conditioning was not cutting down much on the drying time and the cost of the disk mower versus the disc mower conditioner was substantial.  I like the disc mower, simple, easy to transport, but it is a pain to hookup.  I think I paid around $6,000 for a 2013 model.  It is the newest thing I own.  I have an cherry JD 1950s 24T for small squares that cost $2,000.00.  It still has the original decals on it, so I probably paid a lot for a 24T.  However, in 3 years, it has probably missed about 20 bales, and it was mostly because the hay was just too wet.  I went 1,000 bales over 2 days and never missed a bale.  I bought an M&W 4590 round baler at first, but it was not fast enough and very hard to get a bale started in dry hay, so I sold it and moved to a JD 467 due to a forum member recommendation.  Love that baler and I can bale a 4x5 round every 4 minutes.  Paid $8,500.
I only have 4 cows now, so you might think all of this equipment is ridiculous, but my son and I did custom baling for about 10 customers and made good money to cost justify the better equipment.  Couldn't have done it with the old stuff.  Hay has skyrocketed here in Indiana and since I don't have many cows, I am selling my excess.
My take on your hay equipment topic based upon my experience, if you are only doing your hay, then you can buy some cheap stuff and hope it hangs together for a few years.  It will break and you can buy more cheap stuff every few years.  If you buy better equipment, then you can cost justify the higher expense by custom baling or selling your excess hay (sell some of your cows so you have excess) but you may not want to do that.  I couldn't take anymore breakdowns so I went with better equipment.
I am happy I sold most of the cows.  I made a lot more money off of hay this year than anything else and a lot less stress in the winter time.   Hay profit is far better than cattle profits right now.  You have gotten a lot of responses on this topic.  Good luck in whatever you do and if you go the old stuff route, hope you have better luck than me.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2019 at 7:28am
Originally posted by TimCNY TimCNY wrote:
AC7060IL, I almost pulled the trigger on a New Idea Cutditioner for $600 but then pretty much everything I read or was told is that it would be something I'd regret buying. Growing up, at least 2 neighbors used them, it left a mess of the stubble but wow did the hay dry faster than me using a New Holland or JD haybine and then tedding. I just found out the cutditioner is still for sale, price dropped to $500; what can you tell me? I'd rather hear real testimonies than hearsay and opinions. Same goes for anyone else, and I hope this isn't hijacking the thread. Thanks!
New Idea mfg 7’ & 9’ models. My 270 is an earlier chain drive. Later 272 had belt drive - Same with 290/292s. The cutditioner has its place. I probably cut/bale 20-30 acres of grass hay a year, consisting of waterways, road right-a-ways, hedgerow/fence borders, small farmsteads, & small fields(2-3acres).
CONS are: It’s slow cutting1st gear), 540pto so yes it’s a higher fuel usage, stubble cut is higher(4-5”), has 6” cupped flails that need sharpened/edged if it gets into rocks, limbs, & dirt, flail shaft could get bent if you’re not careful(stump,concrete??)
PROS are: Chain drive clutch allows flail rotor inertia to continue to rotate when pto is shut off during tight turns, excellent suck up of downed crop or old mow and optional fluffing/Tedder of rained-on hay. Simple crank height setting(no hydraulics), excellent hay drydown, stems get rubbed (conditioned?)by flail before cutting, higher stubble allows more air flow under cut hay & might allow quicker regrowth that seem to shade out weeds, trails(55mph)behind pickup truck, and quick to grease/lube.
I’m satisfied with it. I’ve been using it for 3 years. I use a angle grinder to lightly sharpen/edge the cup flails twice a year. My 7060(160hp) is overkill, but it’s cab AC is nice when extremely hot/humid. My platform JD3010 diesel (60hp?) is best for tighter places & handles it just fine with less fuel.
cabinhollow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinhollow Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2019 at 8:08am
Gary,
The mud is just were I run my tractor to reload the feeders.
The sheep have 15+ ac to run on that time a year.
The field in the back ground is were they will lamb at.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2019 at 5:47am
Originally posted by allisbred allisbred wrote:
You forgot to mention the good— will suck up rained on hay and make it disappear! Lol. We still have a MC version which was a heavier unit and works very well under trees trimming hedge rows. Make sure to wear glasses!
If I ever buy a flail type mower again it will definitely be an M/C brand.
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2019 at 8:32pm
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2019 at 6:54pm
Had a Cut/Ditioner for my only hay machine ONE SEASON! It left me better than it came. First anD for most it sucked fuel out of my 560 faster than any implement before or since.Second, It constantly required retorqueing of the gear box mount bolts(common in them). Third it broke one of the flail spindles(again common) and the New Idea replacement part was a joke. Machine shop welded in a new stub,chucked the whole rotor up in a BIG lathe and turned down a new spindle. It spun true then. Fourth it left the field looking like you'd cut it with an eggbeater. Fifth,first high was as fast as it would cut without running down hay. Sixth it found rocks that hadn't been seen since the glacier receded.....you all getting the idea I don't like 'em?
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2019 at 6:38pm
Originally posted by cabinhollow cabinhollow wrote:
Here is a picture of my most important piece of hay equipment.
Have three of them and need 1 or 2 more.
Why not feed them out in the field and get the sheep out of the mud?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2019 at 6:36pm
I have one and a similar machine a M-C Rotary Scythe,they are both flail type cutters.
Both take a lot of HP to run and cut slow.The M-C Rotary scythe is the better machine in my opinion but I rarely use either one.I had some expasture land on a place I rented that had some small Cedar stumps that had been cut with a bush hog and left for several years .That Rotary Scythe knocked the stumps out and cut the hay took awhile but it beat tearing up my NH mower on it.Other than situations like that I'd much rather use my NH 456 trailer mower.
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2019 at 5:15pm
I forgot to add that I have a disc mower conditioner that is my main mower. I do not think I would be satisfied if it was my only mower, mostly due to the work rate, but in places it is great to have around. In certain conditions it will add some soil to the windrow so it is out for about any type of silage crop.
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2019 at 5:08pm
I have a 270 cut-ditioner. I like it for stalks, rank old grass hay made from waterways, places with rocks and other cutter bar destroying items. It is simple and rugged. usually put the XT on it and in heavy grass second Hi, stalks 3rd hi. It also will fluff up windrows that have been rained on, and once  I had some rank cereal rye that would not feed into the round baler and we ran those windrows through and baled it all and never plugged. For  $500 Id have it in my arsenal.
TimCNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimCNY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2019 at 2:37pm
I need more than 200 characters for my "signature." I'd love to see that changed to 250!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2019 at 1:07pm
New Idea 270 cutditioner $500,
New Idea 404 rake $500,
Vermeer 605F $700,
So about $1700 invested.
The AC 7060 tractor was purchased 15 yrs ago, depreciated out long ago.
festus51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2019 at 12:05am
Well I have an International 1100 sickle bar mower   $150  and it works
New Holland side delivery rake                                   $400
Vermeer 604 J baler                                                    $2500
IH 485  runs the mower
What ever old Allis I like to rake with
And a 2006 tractor and cab for running the baler,  tractors are used for many jobs not just dedicated to haying.   I run low cost operation as far as equipment goes.
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2019 at 3:33pm
New Holland 912 swather   $4500   5 years ago
  New Holland 290 wire baler $7500  30 years ago 3 tie 16 x 23 x 44 bales 120 lbs
  hire bales hauled @ 1/bale
 Any old tractor that is running,baler has a V4 Wisc so on flat ground any 30 hp tractor.
 Hay sells for $8- $20 per bale
With the years of drought I have bought some $12/bale alfalfa. This year I sold $14/bale oat hay. Cows have been 40 to 80 head all depending how much grass there is from about 3000 acres to graze. The good is no snow the bad is brush and more brush. Grass is only green and growing for 3 months in spring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinhollow Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2019 at 11:39am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2019 at 8:04am
Originally posted by LeonR2013 LeonR2013 wrote:
Kinda reminds me when I grew up and how Dad and I handled cattle. Dad wasn't big on feeding a lot of hay. You'd think I was lying if I told you. We grew quite a few acres of corn so when I got it picked in the fall we turned the cows in on the stalks and the cows would have them cleaned up by spring. In the mean time we had ear corn to grind, to feed the cows night and morning. Sounds like a lot of work doesn't it? Anyway when you called them in and they came over the hill in a dead run, bucking and jumping it made you feel good to see how well they were doing. And in the fall when we sold the calves off and they brought top dollar you felt good again. We never let the cows calve in the fall either. Dad said it was too hard on the cows to have a calf sucking in bad weather. Oh well, a different time and circumstance.      Leon
Pretty close to how we did things back when we grew corn we'd pick or before the picker hand shuck what corn we needed to grind for feed then after grass ran out we'd turn in the cows and hogs in the corn field for the Winter.With the price of cattle these days I think a lot of people will have to return to the low input,low dollar ways of doing things.I never gave it up,my cows never found out what they were missing eating hay from a $500 baler rather than eating hay from a $20,000 baler(LOL)
wade89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wade89 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2019 at 9:11pm
AC 303 Baler   $800
AC 77 Rake    $400
AC 78 Rake    $200
AC Pto Rake/Tedder $100
AC D-17D converted to gas $2000
AC WC Rake tractor $400
IH 1190 haybine. $500
There's other equipment not listed but it's more of a hobby/ taking over for Great Uncles. There's not enough money in hay up north in rock country here to buy newer equipment
12 head of cattle, wife's 3 horses and a mini donkey.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2019 at 8:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2019 at 6:07pm
We run 25 moma cows and finish all our calves to fats. Bale about 200 bales of hay and 200 bales of bedding. Also do 200 bales of custom work. Our diskbine is a Deere 920 bought for $4000 and we have spent about $1500 on it recently. We have a 4 ball Vermeer tedder that cost $1200, 2 Deere 640 rakes that we replaced every bearing in the entire rakes and new rubber teeth at about $1200 each. The baler is a 4x4 Welger (German built) it has net wrap, extra wide pickup and crop cutter and cost $6000. Brother inlaw was a dealer. We also have a 16ft flat wagon with a steel bed for hauling bales that cost us about a $1000 to build.Tractors are a Deere 4230 with cab $12000, 4020 $10,000 and we have a 3020 and loader $7500. Rake with either our D15 $1500 or a Deere 2510 $2800. We have way to much equipment on the farm but most of it is left overs from when we milked 50 cows and raised steers and I have a bad habbit of collecting. LOL Tom
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2019 at 7:29am
Renter round bales nearly everything, they do square bale for another neighbor that sells to Horse People as they will not generally buy rounds here as mold in center is toxic to their animals per the horse people.
Mold in the center?  That ain't supposed to happen.....Mold in the center is toxic to cows too.  Oh I know, I know, cows can take it.  They can, to a point, and are tougher than horses, but a guy shouldn't be making a practice of feeding mold to animals.  Mold in the center and you're looking at a fire risk.
mike 44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2019 at 12:31am
International 684 with loader-7500.00
Farmall H-2,000
Farmall H- 1,700
Allis B with sickle bar -1,500
Allis D15-3,300
Ford 6600- 5,500
Ford 861-2,500
Heston Tedder- 2,000
New Holland 256 Rake-1,500
New Holland 275 Baler- 1,500
1 Steel Haywagon- 1,000
1 wood Haywagon- 500
all the haying equipment was purchased used 10-15 years ago and is in good shape shed kept so gets the job done, have had all the tractors except the 6600 and 684 for seems like forever, those came within the last 6 years. have all this stuff to do 2,000-2,500 bales to feed a few horses and cows. prob don't need that many tractors for what we do but then again you can never have too many tractors!Wink... oh and we have the neighbor mow it with his new discbine.. sure beats the old b with a sicklebar!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 3:32pm
Originally posted by Charlie175 Charlie175 wrote:
Sell the cows and just do hay!
The problem is I have a lot of land I run cows and goats on that'd be impossible to make hay on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 3:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 3:06pm
Around these parts, most smaller beef operators just graze the home place while drilling in wheat/rye/oats starting late September for winter grazing and buy the hay in for winter. I reached just shy of 50 head last year and have free use of the 100 acres attached to mine for grazing March or April thru August/September depending on rains (native grasses).
I graze coastal on my place and not worth baling as only 25 acres, let alone buying the equipment to do it as plenty of folks sell hay. Round bales were running 38-50.00 up until drought of last year when they went over 100.00, now paying 50.00/bale for good 900-1000# bales from same guy I have bought from for years.
Buying out, you do have to watch for weeds as any junk you bring in gets spread throughout your own place and spraying costs for pastures go up.
Everyone seemed to know someone custom baling just a few years ago when 18-20.00/bale was the standard; mow/rake/bale including twine/net wrap and some charged more to bring em' in to where you wanted them stored in a row. Not always baled the tightest so they could charge for more bales or some land owners wanted them loose so as more to sell. Prices I've heard just this year were 25-28.00 to bale and even at that, many don't make enough to rebuild/replace equipment every 5 years.
Funny how "horse quality hay" always brings a premium here, usually 30-40% more than "cow hay" but during drought of last year everyone was buying anything they could get including 3 yo round bales that had saplings growing out of them.
Market dictates, just like anything else and I unrolled bales last year to stretch em'vs. free choice feeding out of my large feeder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 2:27pm
Do people buy those Roto bales? Seems would be hard to haul?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 2:14pm
At the high point we did about 20,000 bales a year with the Roto-Baler. That was an older orangetop that I rebuilt from a fencerow. Everything else was about the same vintage. We were feeding about 20 horses and selling hay.  I continued to upgrade equipment to the point that I was no longer trowing those round bale up and we had machines to do that so all I was doing was stacking. Then as my wife's and my parents passed we lost the farms to the former respective families. Now we own a place and I've sold off all the hay equipment and I rather just CASH rent the ground. No more worries of waiting to cut because of the forecast or a pop up thunderstorm after mowing down hay. If I still had animals, I'd buy hay of the quality I want and be done with it. In this area shipped in quality hay is cheaper than local of self made, when you consider all the costs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 2:01pm
Well— on my math I have have 0$ invested. My equipment is small but all paid for from gains of prior year including fuel and fertilizer. I do not add my labor into the equation as this is something I do for a hobby. I actually started with very low cost equipment and constantly upgrade if there is any profit. Sometimes it does take awhile. I started an account with an “x” number a few years ago and that number is in the plus. Alfalfa made the most gains and also had the most input. As I started making hay, several neighbors had small fields that to date have not had any rent pay. I may never be a big operator at this rate but have no payments. Finishing cattle has been a different story.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 1:32pm
Started to tell ya then I got a cattle price update and got dizzy and almost fell over and was thinking about your question and could barely set up from the almost pass out. Don't want to think about it.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 1:07pm
We don't have any livestock, we just custom bale.
AC 303 Baler       $600.00
AC Roto Baler      $250.00
AC 78G Rake        $350.00
AC Hay Conditioner $300.00
AC 80R Mower       $125.00
AC Hay Rack        $125.00
AC CA Tractor      $800.00
Total             $2550.00
Edited by DennisA (IL) - 19 Dec 2019 at 1:08pm
Thanks & God Bless
Dennis
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 12:49pm
Nah,you have to have cows to eat the junk you can't sell.
This page was generated in 0.516 seconds.
