Hauling an All Crop
westfork View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote westfork Quote  Post ReplyReply Direct Link To This Post Topic: Hauling an All Crop
    Posted: 03 Feb 2019 at 9:00pm
Would a Donahue implement trailer haul a All Crop model 72?  I would like to back it on over the hitch.  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2019 at 3:45am
there are different sizes of Donahue trailers. weight wize...yes they will haul the combine. grease the slider rails up real good.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2019 at 3:59am
Their was a thread on Agtalk about it in the last 3-4 months
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2019 at 4:23am
A 72 will have the roller bearing wheels right? why not just pull it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote westfork Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2019 at 7:33am
Going to look at one today. Will bring a tape measure.  My 72 is early with bushings.
Thanks for the agtalk site. Another place to visit.  I did find the discussion on trailering the All Crop.  I have pulled it  down the road, which would be the easiest.  Loading on a 8 foot wide trailer is nerve racking.  The tires are split down the middle.  The Donahue I am looking at is only eight feet wide. But not as far to fall if I miss.  I have other implements to haul as well.
Thanks for the help
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2019 at 9:10am
Any 102” wide trailer will work. No dismantling required . Just have the hang over on the right side on put on a couple of flags and/or flashers. In the pictures is a 66 All Crop. The tread spacing should be the same on the 72 has the 66. The header will over hang an extra 6”-8”.
Sorry for the image size
Edited by DennisA (IL) - 04 Feb 2019 at 9:12am
Thanks & God Bless
Dennis
GreenOrange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 2:36pm
I hauled my 1969 72 All-Crop on my 102" Deckover. One plus you have going for you is the wheel tread is actually narrower on the bushing models than on the later roller bearing models. For me, I was able to get the bin side tire entirely on the trailer, and the header side tire over half on. I was just over flush with the trailer edge on the drivers side, and on the passenger side,the header hung over plenty - probably close to 2 feet total (could be less with the bushing wheels as I don't know if the later ones were widened equally on each side). After it was loaded, made blocks under each side of the axle so it could be bound down tight and avoid bouncing. As DennisA suggests, I put magnetic flashers on it and made the 360 mile trip without issue - no trouble at all. Personally, I wouldn't even attempt it on a 96" wide trailer, but it may be possible.
Edited by GreenOrange - 09 Feb 2019 at 4:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote westfork Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 8:23pm
Thanks for all of the ideas.  I would be hauling the All Crop on a regular basis during the growing season.  Not comfortable loading it on a trailer with the tires overhanging.  Looked at a Donahue Implement trailer and with a few modifications should work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 10:37pm
I wouldn't want to do it on a regular basis either - once was enough for me!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 10:47pm
just remember, loaded Donahue trailers are not allowed on interstates like other trailers are.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2019 at 7:29am
Out of curiosity, how are you guys actually getting it on the trailer? Are you backing it on?
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2019 at 7:46am
You can haul it on a 10 foot donahue....back it on, but don't lower it all the way.(belly out).it needs to sit on the front 2/3s of the trailer after adjusting wheels....road rules apply...you can't see behind you....done this a few times...Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2019 at 9:37am
I pulled mine on the trailer backwards with a winch. Offered much better control and ability to keep it centered how I wanted.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2019 at 11:05am
x2
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2019 at 11:08am
We have a 10' 4 axle Donahue at the farm its to wide to pull with a truck must use a tractor its over 12' wide requires a permit to pull with a truck. can pull with a tractor as its farm equipment. WE have hauled a 12'x 30' fuel tank and calf shelters on it but always use a tractor. even a ' 8 wide Donahue is 10' outside width and requires a wide load permite to pull on road.
Edited by Dakota Dave - 08 Feb 2019 at 11:10am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2019 at 12:57pm
I think I would use a 8’-6” wide trailer with extensions on the right side.
Thanks & God Bless
Dennis
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2019 at 1:47pm
Hauled a 66 Big Bin from New Harmony, In. to Marion, In. on a 96" trailer few years back. Used a loader to back it on (carefully), once it was loaded, I removed wheels and set frame on 6 X 6 blocks, chained it down, put flags on right side overhang, wide load signs on and headed home - rode like a baby in a cradle!
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2019 at 10:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2019 at 7:32am
And what portion of the road patrol offficers even know this? And of the ones that do how many care enough to be a Dick? Remember towing my soil finisher home from Illinois pulled up to this stop sign edge of the finisher dangling over both shoulders of the road. County sheriffs deputy just motioned me on and went on his way.   Folded up sitting on my gooseneck it 13 foot wide towed it from Kansas back to Michigan took I-80 right along the south edge of Chicago. If the OP uses common sense he would be just fine.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2019 at 12:59pm
I backed an all crop onto a gooseneck flatbed one time. Hauled it 100 miles into a headwind. Think I got about 2 miles to the gallon
aerodynamics aren't so good. Lol. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2019 at 2:32pm
After some thought, you also can put one or two castering wheels under the axle matching up to your ramps ....I've tried picking one up(72) with a front end loader boom...failed..not  a big enough horse.....Mark
This page was generated in 0.297 seconds.
