Hardened valve seats
Smiling John View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smiling John Quote  Post ReplyReply Direct Link To This Post Topic: Hardened valve seats
    Posted: 24 Jan 2018 at 5:43pm
Did all D17's have hardened valve seats?  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2018 at 7:38pm
they were made when leaded gas was the norm so I'm guessing not any had em.You can install them.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2018 at 7:59pm
That's right. More that likely it would need stainless valves, so if you put them in then you would need seats. When apart just check them and then you'll know. If you need to save a buck and your head shop is willing, you can put late model Ford 302 ex valves and Chevy intake in the head. Works real good. There are so many of those heads laying around, that you can find a real good used set of them.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2018 at 10:33pm
The WD, WD-45 and D-17 all come from the factory with hardened seats for the exhaust valves.
Seats for the intakes are available from A-C but the head must be counterbored
to accept them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 12:21pm
A-C was light years ahead of the competition on wet sleeves and hard exhaust valve seats. Someone please tell me if anyone had wet sleeves before 1934 ?? (the first WC era).
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 2:08pm
The Farmall Regular and F-series tractors had wet sleeve engines I believe; with the Regular starting in 1923 and the F-20 being the upgrade of that tractor in 1932. I have an F-20 and have never had it that far apart but I am about 99% sure they have a wet sleeve engine as did the Regular. When IH put in hardened valve seats I have no idea.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 4:23pm
Well, if they did have wet sleeves in the F-20/Regular era, they went away from them in 1939 with the M and the H.
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 5:55pm
I have a IH 300 utility with a 169 gas engine I bought about 20 years ago.  It is a 1956 model.  I bought it cheap, with a dead hole.  It broke a chunk off of an intake valve.  It had both intake and exhaust were hardened seats.  I don't think it had been apart before.  It has dry sleeves in it though.  Have to have a pretty good sleeve puller to get those out.  I redid the TA and resealed the trans at the same time, pertronix ignition and an alternator.  Been a pretty good unit, haven't done much to it since then.
Edited by LB0442 - 25 Jan 2018 at 6:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 6:18pm
H Farmall had dry sleeves too. Guy I used to work with pressed in new ones for his restore job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 7:59pm
 They go in much easier after a few hours in the freezer.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 8:30pm
I re-sleeved my 8N when I overhauled it, and that's one thing I like about the pre-1950 N's. The dry sleeves almost fall in with very little pressure after being in the freezer a while. No press needed.
Edited by CrestonM - 25 Jan 2018 at 8:30pm
