Hard materials carving
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Hard materials carving
    Posted: 18 Nov 2025 at 3:43am
As with the Hard Concrete Drilling post, how does one go about 'Carving, a Iron/Cobalt/Nickel rock into a statue, in the 11th century of Tibet?  Not sure anyone today can do so with primitive tooling, and NO Steel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2025 at 7:11am
Patience and a lot of hard work using sharp rocks to chip away at it. Similar to the way some of my ancestors made arrow heads and spear points.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2025 at 12:38pm
Yet this was Iron Cobalt and Nickel, we can have tough times Machining High Nickel Blocks!!  Not gonna do much gouging with a Rock.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2025 at 2:38pm
Must’ve been aliens eh?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2025 at 3:38pm
YEP... my vote is for ET.... Not too many other options !  Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2025 at 6:47pm
The Science stated that Tibetan Monks formed with Hammer and Chisel.  HOWEVER, did not have Iron or Steel save for the Meteor in 11th century in Tibet.  Did not begin fashioning Metal Prayer Idols until 13th.  Kind of like the Granite Blocks in Peru, fit tight enough cannot slip a sheet of paper between and Predate the Inca or Aztec credited to have made.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2025 at 8:59pm
SOOO............ we are back to ET !!!   Clap
way too many things from 1000 - 2000 years ago that can NOT be explained even with todays technology..
Edited by steve(ill) - 18 Nov 2025 at 9:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2025 at 3:19pm
A great deal of it we still cannot achieve today.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 6:59pm
We the unwilling can do the impossible in a given amount of time
If you wanted it done today , you should have asked yesterday
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2025 at 9:15am
If it wasn't ET... who did it? Chiseling Nickel/Iron with rocks seems like an unlikely answer. I'd more believe the world has been inhabited far longer than science will admit. If the planet is 4.5 billion years old (google) advanced life could have 'come and gone' a couple times now. Everything would rust and disintegrate in a million years except the stonework which seems like where we are today.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2025 at 11:26pm
It's not carved at all, there's no carving markes.
To make this, all one needs, is beeswax, some quicklime or clay slurry, and a good, hot fire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 3:09am
Thanks Dave. One slight variable. Not much to any clay high in Tibet mountains, no record of Clay Kiln or other mineral recovery ovens been built there. Most of the nation is above tree line where few to any bees for the wax availibility.
Edited by DMiller - Yesterday at 3:10am
fjdrill View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote fjdrill Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 16 minutes ago at 6:48am
Imma thinking it's cast. Look inside the arms at elbows. Also, inside the what looks like rope loop below his left shin. If it was carved those would have been easy details to correct to make more crisp like the detailed cuffs on arms and ankles. Wonder what the back looks like? Might have been carried up to the Monks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 10 minutes ago at 6:54am
No one is certain Who came up with or produced it, is not Cast as can see the raw Meteorite Base was derived from.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 18 minutes ago at 12:46am
Something is amiss - article says the Swastika carved into - DAAA - it stands out not carved in .  Someone has no idea and is making up stories .
 That marker on chest has been used in many parts of the world for many generations ands yet now or since 1932 to 1945 has become something else
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 5 minutes ago at 3:59am
Navajo, Tibetans, Hindu and Asian religious groups all used the Swastika. World wide on a minimally populated Earth among peoples that not ever presumably met.
This page was generated in 0.041 seconds.
