Hard materials carving |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34633 |
Topic: Hard materials carvingPosted: 18 Nov 2025 at 3:43am |
As with the Hard Concrete Drilling post, how does one go about 'Carving, a Iron/Cobalt/Nickel rock into a statue, in the 11th century of Tibet? Not sure anyone today can do so with primitive tooling, and NO Steel.
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6524 |
Posted: 18 Nov 2025 at 7:11am |
Patience and a lot of hard work using sharp rocks to chip away at it. Similar to the way some of my ancestors made arrow heads and spear points.
DMiller
Posted: 18 Nov 2025 at 12:38pm |
Yet this was Iron Cobalt and Nickel, we can have tough times Machining High Nickel Blocks!! Not gonna do much gouging with a Rock.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12285 |
Posted: 18 Nov 2025 at 2:38pm |
Must’ve been aliens eh?
Joined: 11 Sep 2009 Location: illinois Points: 88864 |
Posted: 18 Nov 2025 at 3:38pm |
YEP... my vote is for ET.... Not too many other options !
DMiller
Posted: 18 Nov 2025 at 6:47pm |
The Science stated that Tibetan Monks formed with Hammer and Chisel. HOWEVER, did not have Iron or Steel save for the Meteor in 11th century in Tibet. Did not begin fashioning Metal Prayer Idols until 13th. Kind of like the Granite Blocks in Peru, fit tight enough cannot slip a sheet of paper between and Predate the Inca or Aztec credited to have made.
Posted: 18 Nov 2025 at 8:59pm |
SOOO............ we are back to ET !!!
way too many things from 1000 - 2000 years ago that can NOT be explained even with todays technology.. Edited by steve(ill) - 18 Nov 2025 at 9:00pm |
DMiller
Posted: 19 Nov 2025 at 3:19pm |
A great deal of it we still cannot achieve today.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42068 |
Posted: 20 Nov 2025 at 6:59pm |
We the unwilling can do the impossible in a given amount of time
If you wanted it done today , you should have asked yesterday |
scott
Joined: 12 Sep 2009 Location: michigan Points: 2764 |
Posted: 24 Nov 2025 at 9:15am |
If it wasn't ET... who did it? Chiseling Nickel/Iron with rocks seems like an unlikely answer. I'd more believe the world has been inhabited far longer than science will admit. If the planet is 4.5 billion years old (google) advanced life could have 'come and gone' a couple times now. Everything would rust and disintegrate in a million years except the stonework which seems like where we are today.
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6094 |
Posted: 21 hours 17 minutes ago at 11:26pm |
It's not carved at all, there's no carving markes. To make this, all one needs, is beeswax, some quicklime or clay slurry, and a good, hot fire.
DMiller
Posted: 17 hours 34 minutes ago at 3:09am |
Thanks Dave. One slight variable. Not much to any clay high in Tibet mountains, no record of Clay Kiln or other mineral recovery ovens been built there. Most of the nation is above tree line where few to any bees for the wax availibility.
Edited by DMiller - 17 hours 33 minutes ago at 3:10am |
fjdrill
Silver Level Access
Posted: 13 hours 55 minutes ago at 6:48am |
Imma thinking it's cast. Look inside the arms at elbows. Also, inside the what looks like rope loop below his left shin. If it was carved those would have been easy details to correct to make more crisp like the detailed cuffs on arms and ankles. Wonder what the back looks like? Might have been carried up to the Monks.
DMiller
Posted: 13 hours 49 minutes ago at 6:54am |
No one is certain Who came up with or produced it, is not Cast as can see the raw Meteorite Base was derived from.
