Hard Hat ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2022 at 5:56pm
Originally posted by FREEDGUY FREEDGUY wrote:
[QUOTE=steve(ill)]The dumbasses that left tools on top of a ladder should have been TERMINATED on the spot
YEA... thats going to do a LOT OF GOOD as you stand there will a drill buried 2 inches into YOUR HEAD !!   The hat is PREVENTATIVE MAINT !!!
[/QUOTE
Well Stevie, the OP never said the size of drill bit,did he Wink ?? The milk jug  I was given would NOT stop a "spear" of less than 3/4" from a height of 10', best case from that impact would be the headband shearing off both ears from the side of my head OuchOuch !!
BTW, check your spelling LOLLOL !!!
With no ears, you'd look just like a fish!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2022 at 5:58pm
This is YOUR HEAD without hard hat.... Pipe dropped 10 ft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2022 at 6:12pm
Wore one as required for job for 24 years, never cared for them but wore regardless as 'Was The Rule'.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2022 at 7:03pm
alberta phil thats just like mine,   it was my grandpa hudson and he retired in 72  i have a winter ear flap liner in it right now to keep the ears warm and the rain and snow off and it has my company sticker on the front its as light as a ball cap . i always get some kind of comment when i wear it to town to the part stores and differant places
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2022 at 7:17pm
Mechanic at MDOT Garage was supposed to wear a Bump Cap when he had Trucks on the lift. Came in one afternoon and he had a big shaved area on the back of his head with a large band aid on covering. Seems he was working under a truck on the lift with no bump cap dropped a wrench and when he straightened up from picking the wrench up hit his head on the cutting edge of the trucks underbody scraper! Took 10 stitches to close the wound! An accident report was filled out and in it he stated his bump cap fell off and he hit his head when he was putting it back on! I said " Your a pretty good storyteller "!
Edited by klinemar - 03 Mar 2022 at 7:18pm
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2022 at 10:35pm
HudCo, Mine originally belonged to my  ex father-in-law who was a petroleum engineer with Imperial Oil (Esso).  I inherited it when he passed on and have used it ever since.  Not in the oilfield anymore but still wear it around the farm if the job warrants it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2022 at 11:12pm
most hard hats are slick, and usually if anything falls and hits them, that object will usually glance off them saving it from breaking it or your head
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2022 at 6:38am
Same here.
We only have to wear them on commercial work.
Don’t like them either but I sure like groceries and our home.šŸ‘
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2022 at 6:39am
[QUOTE=steve(ill)]<span style="color: rgb0, 0, 36; : rgb254, 252, 212;">The dumbasses that left tools on top of a ladder should have been TERMINATED on the spot</span>
</span>
<span style="color: rgb0, 0, 36; : rgb254, 252, 212;"><b style="">YEA... thats going to do a LOT OF GOOD as you stand there will a drill buried 2 inches into YOUR HEAD !!Ā  Ā The hat is PREVENTATIVE MAINT !!!</span>
[/QUOTE
Well Stevie, the OP never said the size of drill bit,did heĀ WinkĀ ?? The milk jugĀ  I was given would NOT stop a "spear" of less than 3/4" from a height of 10', best case from that impact would be the headband shearing off both ears from the side of my headĀ OuchOuchĀ !!
BTW, check your spellingĀ LOLLOLĀ !!!
But can you imagine him with no beers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2022 at 6:45am
Maybe using his hard hat for a Ice Carrier?!?!?!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2022 at 6:54am
Last three I wore working, have a Green Full Brim MSA in the truck I drive but is well out of date and could care less if destroy it.  Had my Grandfathers Aluminum one, even the suspension was intact in it, was leather for that back in the day.  Went to my older brother so his son can have it when we are all gone.
Tabs on side of Black one were for Hearing Protection muffs or intercom speaker ear covers for working with the control room.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2022 at 2:19am
i never had a problem wearing a hard hat on any job site...until...now this was before the cancer choosing a color for the survivors and other hoping to survive. yep i'm talking about pink! you know...PINK! a local company contacted me to remove some items from their building site as construction progressed. i usually always had my own hard hat in my truck, the company said i had to wear one on site when i came. no problem...and i pulled out my hat. they told me no...i would hafta wear a pink hard hat! i told them this dude don't wear pink hard hats! they told me i couldn't be on the property without it! i left, told them to find someone else to do what was needed to be done. about 3 days later i gits a call from the boss man there. and we have this conversation again, he said he'd let me wear my yeller one, as they really needed me to haul the items there.  worked for for me!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2022 at 2:20am
oh....and now i will wear about anything pink, supporting all those fighting cancer!
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2022 at 5:33am
Most commercial projects I see, safety gear includes hard hats, eye protection, hi vis vest with reflective tape, work boots sometimes steel toed, and hearing protection. OSHA regs. No like, no work. Was in a residential construction project yesterday. 3 guys on ladders swinging hammers, drilling holes with big auger bits, and one with a sawzall cutting off excess top plate under a beam. I never felt so vulnerable before reading this thread.
iowallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iowallis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2022 at 7:18am
I work in a processing facility with pipes all over and platforms of various levels. Part of our PPEs are bump caps, basically low grade hard hats without the "suspension" in them, the machine maintenance crew wears true hard hats. The cap has saved my noggin a few times. A number of years ago we were shut down and no production for a tour of corporate officials. No production going on and defined walk zones so no caps (or other PPEs) required. I almost felt naked walking into the production area without my bump cap and safety glasses on.
Edited by iowallis - 05 Mar 2022 at 12:06pm
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2022 at 12:07pm
Thumbs Up I sure am glad you added this cause I thought you where the tuff guy. Wink You know like the rodeo cowboys at the championship in Los Vegas have their "Tuff enough to wear pink" day.
The whole thing might be over done in the sports world. But one of the biggest dirt moving contractor in California when I was a kid had pink as his cooperate color. Went on to build a big hotel and restaurant that uses pink as main color. The Madonna Inn, is still going even though he died about 15 years ago. In the original part it is built out rock or painted pink. So Shameless you might be happiest in the Cave Man room all rock all the time. Wink An you did not need a good aim in the men's room of the restaurant (like putting it in a gas tank) a whole wall is a waterfall, you get to add too.LOL
This page was generated in 0.291 seconds.
