Harbor Freight Saw Blade |
klinemar
Joined: 14 Sep 2009 Location: Michigan Points: 8074 |
Topic: Harbor Freight Saw BladePosted: 05 Oct 2018 at 9:42am |
I bought a 7 1/4" carbide metal cutting blade for my Skil Saw from Harbor Freight. Used it for the first time today on some channel steel 3/16 thick. Cut through it like a hot knife through butter! No grinding ,hot sparks flying, just like cutting a 2x4 ! Every once in awhile Harbor Freight has a good product !
Joined: 11 Sep 2009 Location: illinois Points: 90793 |
Posted: 05 Oct 2018 at 4:33pm |
I will have to look into that.. didn't know they had such a thing for skill saws.
shameless dude
Posted: 05 Oct 2018 at 6:08pm |
what was the name on the blade?
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25243 |
Posted: 05 Oct 2018 at 6:24pm |
better go back and buy the whole batch of them ! especially if they're on sale. Local store here had 'ultra thin' 4.5 cutoff wheels at a great price(75%) so I bought 1 pkg of 10. Sure wish I'd tried them as they were great but by the time I got back to store , they were sold out. Next sale,same item, LOUSY..yeah I bought 4 pkgs of them..arrgh...
Posted: 05 Oct 2018 at 9:30pm |
klinemar
Posted: 05 Oct 2018 at 10:50pm |
Yep Steve found the blade! I might have to buy some more!
HD6GTOM
Posted: 06 Oct 2018 at 12:28am |
Do not use those if your saw has a plastic case. Years ago, many years younger I did.
shameless dude
Posted: 06 Oct 2018 at 1:26am |
I need blades to cut tin roofing. and my Dewalt has a plastic case....why Tom?
jaybmiller
Posted: 06 Oct 2018 at 6:08am |
cause the white HOT metal cuttings WILL melt the plastic guard around the saw blade. You'll figger that out when a long stream sparks come shooting THROUGH the plastic.. yeah BTDT.... NOW I have a metal saw for cutting metal... ..though my $400 MG saw went 'walking' ( probably into the 'contractors' trailer).. |
klinemar
Posted: 06 Oct 2018 at 7:56am |
My Skil Saw has a plastic case around the motor and metal where the saw is and I have used it with a fiber cut off wheel for years with no problem. Talk about sparks and sl*g! This Harbor Freight blade gave off very little sparks off course it is new and still sharp.
Edited by klinemar - 06 Oct 2018 at 7:56am |
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5061 |
Posted: 06 Oct 2018 at 8:08am |
For metal roofing try putting a regular wood saw blade on backwards, seems to work well.
Dusty
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12418 |
Posted: 06 Oct 2018 at 9:16am |
Seen the backwards blade trick work. Made one helluva noise, but it worked.
Don’t have first hand knowledge of the HF blade, but I believe MK Morse introduced the Metal Devil blade about 5 years ago. Generated very little heat. Edited by Tbone95 - 06 Oct 2018 at 9:16am |
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11397 |
Posted: 06 Oct 2018 at 2:34pm |
I always used a plywood blade in backwards for metal roofing
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8779 |
Posted: 06 Oct 2018 at 4:37pm |
I agree with Tbone about the noise that a backwards blade makes when cutting roof metal. Double or triple ear protection is required. Darrel
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42266 |
Posted: 06 Oct 2018 at 5:04pm |
Son has a Milwaukee metal cutting saw - has a pocket on side of guard to catch metal chips -blades are carbide tipped - one problem is the steel now on the market has carbon pockets and when the blade teeth hit these hard spots they will shear off or chip.
A low cost blade put in backwards will work for sheet metal or metal roofing but it does leave somewhat rough edge of pushed to hard and fast |
Posted: 06 Oct 2018 at 5:12pm |
klinemar.. you said you cut 3/16 plate... I thought this was a sheetmetal blade ? I have seen steel saws, but the ran about 1000 rpm, not 3600 ??
Tbone95
Posted: 06 Oct 2018 at 8:27pm |
The time I saw the backwards blade work, it was on aluminum plate. I don’t recall the exact thickness, but it was 3/8 to 1/2 inch. The noise was BRUTAL.
The metal devil was cutting 3/16 angle iron on a decent, but plain ol skill saw. It was awesome. |
omahagreg
Joined: 11 Sep 2009 Location: Omaha, Nebraska Points: 2809 |
Posted: 06 Oct 2018 at 8:36pm |
I needed to cut a new metal bath partition once. Parts runner got me a Lenox branded, toothed blade from Lowes-I said somethings I regret about his competence, but put it on my worm drive Skilsaw anyway. I was cutting 4" off, so had some area to 'play' with. I HIGHLY recommend that blade to anyone. SMOOTH and fast! I realize partitions are 2 sided sheet metal, but the packaging said it works up to 1/4" steel, if my memory has not failed me!
Greg Kroeker
1950 WD with wide front and Freeman trip loader |
shameless dude
Posted: 06 Oct 2018 at 9:04pm |
I hope you appoligised to yer worker! thanks ya'll, i'll try the backwards blade one of these days!
HD6GTOM
Posted: 07 Oct 2018 at 8:25pm |
Yep it melts the case. I did it several years ago. Dog gone it. I was at HF today and forgot to pick up one of these blades. Although I am done cutting steel for the year, I gotta add on to the east side next year. Dang good reason to go back next Saturday. Old gal says I can have that day off.
klinemar
Posted: 08 Oct 2018 at 6:03am |
I tried the backwards saw blade and did not like the cut it left in steel roofing or the noise.
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 08 Oct 2018 at 7:34am |
Had the piece of metal siding on the saw horses and used a backward plywood blade to cut it. (plywood blades have more teeth, so a little quieter) So,,,,,,I'm sawing along and all of a sudden it kinda bogged down. Well, that's usually because I'm standing on the cord,,,,,which I wasn't... so I started in again and it kind of grunted through the next couple inches and then cut real well again. As it got through the 'bogged down area', I heard a 'clunk' and there laid the tail off of my steel square...
![]() Yep, cut clean through it....When cutting steel roofing or siding, it's noisy for sure, but it works. I'd rather use a shear!! |
Dusty MI
Posted: 08 Oct 2018 at 8:59am |
I've got a little question about saw blades.
I would like to put a 4-1/2" blade in my side grinder, but can't find one with a 7/8" bore. Can a saw blade be drilled drilled to a larger bore, or are they too hard to drill ? Dusty
