Harbor Freight jackstands
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2020 at 1:50pm
I read some where and didn't mark it, (Duhh moment) that the machines that were being used to make them were falling apart and they couldn't keep a tolerance going. I couldn't verify if that was true or not, but for as long as they were made 3 tonners first then the 6 tonners came along, probably on the same machines (more wear, tear, and abuse) it makes sense to me.
Gordy, you could check with them on the #'s to make sure, but I suspect they are OK.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 11:31am
Here's a video of the problem and a look at the old 6  ton jack pawls etc and the new ones.
 New ones are $50
[TUBE]Gn7FPbT2fxQ[/TUBE]
Edited by chaskaduo - 26 May 2020 at 11:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 4:46pm
Thanks Chas............ i assumed the arm had to be FULLY EXTENDED and then wobble in the hole...... Never thought that the TEETH on the arm could all be under size or no quality control from the factory... Sure was OBVIOUS when you looked at one disassembled... Now i need to check all of mine !! .......... but they are 20 years old or more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 6:30pm
Technically, you should also bend the tab, on the side of the bottom half of the JS, to eliminate side play, between the 2 halves...Wink
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 6:38pm
Thanks for sharing this !
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2020 at 1:55pm
Well, here is a picture of my "modified" 6 ton stands to get an extra 5 inches of height.. Probably had these 15 years or more. They appear to be the same ones he bought "NEW" in the movie.. Plenty of teeth engagement... No longer have stickers so i dont know the PN.
I wonder if they are built in TWO different factories ?  the RED factory and the GREY factory ? ............ anybody have a BAD RED one ?
Edited by steve(ill) - 27 May 2020 at 2:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2020 at 5:40pm
I traded in the 2 I had, today.  Didn't have any others in stock, but I'm in no hurry, I'll pick 'em up when I see 'em...Wink
