Harbor Freight jackstands |
  Page <12 |
   chaskaduo
   Joined: 26 Nov 2016 Location: Twin Cities Points: 5200  |
      Quote   Reply
     Posted: 23 May 2020 at 1:50pm |
I read some where and didn't mark it, (Duhh moment) that the machines that were being used to make them were falling apart and they couldn't keep a tolerance going. I couldn't verify if that was true or not, but for as long as they were made 3 tonners first then the 6 tonners came along, probably on the same machines (more wear, tear, and abuse) it makes sense to me.
  Gordy, you could check with them on the #'s to make sure, but I suspect they are OK.
   chaskaduo
      Quote   Reply
     Posted: 26 May 2020 at 11:31am |
Here's a video of the problem and a look at the old 6  ton jack pawls etc and the new ones.
   New ones are $50 [TUBE]Gn7FPbT2fxQ[/TUBE]
Edited by chaskaduo - 26 May 2020 at 11:38am  |
   Joined: 11 Sep 2009 Location: illinois Points: 88570  |
      Quote   Reply
     Posted: 26 May 2020 at 4:46pm |
   Thanks Chas............ i assumed the arm had to be FULLY EXTENDED and then wobble in the hole...... Never thought that the TEETH on the arm could all be under size or no quality control from the factory... Sure was OBVIOUS when you looked at one disassembled... Now i need to check all of mine !! .......... but they are 20 years old or more.
   DiyDave
   Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54418  |
      Quote   Reply
     Posted: 26 May 2020 at 6:30pm |
   Technically, you should also bend the tab, on the side of the bottom half of the JS, to eliminate side play, between the 2 halves...
   ACinSC
   Joined: 16 Dec 2015 Location: South Carolina Points: 3064  |
      Quote   Reply
     Posted: 26 May 2020 at 6:38pm |
   Thanks for sharing this !
      Quote   Reply
     Posted: 27 May 2020 at 1:55pm |
   Well, here is a picture of my "modified" 6 ton stands to get an extra 5 inches of height.. Probably had these 15 years or more. They appear to be the same ones he bought "NEW" in the movie.. Plenty of teeth engagement... No longer have stickers so i dont know the PN.
  I wonder if they are built in TWO different factories ?  the RED factory and the GREY factory ? ............ anybody have a BAD RED one ? Edited by steve(ill) - 27 May 2020 at 2:02pm  |
   DiyDave
      Quote   Reply
     Posted: 27 May 2020 at 5:40pm |
   I traded in the 2 I had, today.  Didn't have any others in stock, but I'm in no hurry, I'll pick 'em up when I see 'em...
  Page <12 |
| Forum Jump | Forum Permissions  ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
