Hand Clutch Throwout vs. Spring Trip Plow Beams |
wjohn
Topic: Hand Clutch Throwout vs. Spring Trip Plow BeamsPosted: Yesterday at 3:12pm |
For anyone who has plowed with a WD/WD-45 and experienced both the hand clutch trip/throwout kit, and a 60- or 70-series plow with individual spring trip mechanisms on the shanks/bottoms... Does one work better than the other?
I don't think AC had auto-reset trip bottoms on those models of plows, so I think you were stopping forward travel with either mechanism. You either had to shift to reverse and re-engage the hand clutch to unhook a plow bottom from a big rock/root, if the throwout mechanism had tripped it... or you had to stop and reset the plow bottom that tripped. Correct? I think I have enough parts to put the hand clutch throwout on one of my tractors, so I'm probably going that route. I was just curious if there was a big advantage to buying a 60- or 70-series plow with the trip bottoms.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5218 |
Posted: Yesterday at 3:18pm |
The 60 or 70 series plows were not spring trip, but shear bolt beams. The trip beams started with 80 series plow frames.
Often I've had trip beam plows that would reset themselves after stopping by just lifting the plow quickly.
dr p
Joined: 24 Feb 2019 Location: new york Points: 1489 |
Posted: Yesterday at 6:03pm |
I have a hand clutch throwout and a lot of rocks. It is very difficult to set it correctly. It tends to be very sensitive especially when using a disk plow
wjohn
Posted: Yesterday at 6:37pm |
The spring trip beams are listed in Section III of the moldboard plows parts catalog for all three of those plow frame series, with some variations to the spring trip design changing in 1963. I have seen 60- and 70-series with spring trips. From looking at the 80-series frame pages in that catalog, it looks like the spring trip beams may have become standard on the 80-series, and were only an available option on the 60- and 70-series?
wjohn
Posted: Yesterday at 6:38pm |
Hmm. So that would be a vote against, perhaps.
dr p
Posted: Yesterday at 7:05pm |
Sometimes that is the fun in it
tom51
Bronze Level Access
Posted: 21 hours 52 minutes ago at 9:49pm |
My dad had aW/D-45 with the hand clutch trip and a model 52 3-14 plow we didn’t have many rocks but when it found one it worked very well. Broken bolts and plow shares were expensive back in the early sixties
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2322 |
Posted: 10 hours 54 minutes ago at 8:47am |
My WD with the clutch trip worked well, the plow would usually jump over the rock after tripping, then you just pull the clutch and go. very seldom hook a rock and stay that way.
