Hand Clutch Throwout vs. Spring Trip Plow Beams
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: Hand Clutch Throwout vs. Spring Trip Plow Beams
    Posted: 17 Jan 2026 at 3:12pm
For anyone who has plowed with a WD/WD-45 and experienced both the hand clutch trip/throwout kit, and a 60- or 70-series plow with individual spring trip mechanisms on the shanks/bottoms... Does one work better than the other?
I don't think AC had auto-reset trip bottoms on those models of plows, so I think you were stopping forward travel with either mechanism. You either had to shift to reverse and re-engage the hand clutch to unhook a plow bottom from a big rock/root, if the throwout mechanism had tripped it... or you had to stop and reset the plow bottom that tripped. Correct?
I think I have enough parts to put the hand clutch throwout on one of my tractors, so I'm probably going that route. I was just curious if there was a big advantage to buying a 60- or 70-series plow with the trip bottoms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2026 at 3:18pm
The 60 or 70 series plows were not spring trip, but shear bolt beams. The trip beams started with 80 series plow frames.
  Often I've had trip beam plows that would reset themselves after stopping by just lifting the plow quickly.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2026 at 6:03pm
I have a hand clutch throwout and a lot of rocks. It is very difficult to set it correctly. It tends to be very sensitive especially when using a disk plow
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2026 at 6:37pm
The spring trip beams are listed in Section III of the moldboard plows parts catalog for all three of those plow frame series, with some variations to the spring trip design changing in 1963. I have seen 60- and 70-series with spring trips.
From looking at the 80-series frame pages in that catalog, it looks like the spring trip beams may have become standard on the 80-series, and were only an available option on the 60- and 70-series?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2026 at 6:38pm
Hmm. So that would be a vote against, perhaps.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2026 at 7:05pm
Sometimes that is the fun in it
tom51 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom51 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2026 at 9:49pm
My dad had aW/D-45 with the hand clutch trip and a model 52 3-14 plow we didn’t have many rocks but when it found one it worked very well. Broken bolts and plow shares were expensive back in the early sixties
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2026 at 8:47am
My WD with the clutch trip worked well, the plow would usually jump over the rock after tripping, then you just pull the clutch and go.  very seldom hook a rock and stay that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2026 at 8:25am
Since I have the parts it sounds like I should give the hand clutch trip mechanism a go. Maybe I can get it dialed in well enough.
I do also have one of the spring hitches for the WD pin hitch plow but that would just cushion things slightly.
This page was generated in 0.238 seconds.
