Hand clutch slip |
   bmartin55
      Quote   Reply
     Topic: Hand clutch slipPosted: 13 Apr 2013 at 8:00pm  |
   can i bolt my clutch solid.   it went sliping today at the pulles. dont really want to use it..can i take that trane out..  i need to lose weight any   way''thanks  bob
   MACK
      Quote   Reply
     Posted: 13 Apr 2013 at 10:15pm |
   Take it out, use another hub like the clutch bolts to and put it on input shaft then bolt the two togather.   MACK
   bmartin55
      Quote   Reply
     Posted: 13 Apr 2013 at 10:21pm |
   mack..wher can i find a hub to do that with...can i take trane out ..
   MACK
      Quote   Reply
     Posted: 14 Apr 2013 at 7:24am |
   I should have one or use two clutch hubs which I also have.  MACK
   firephight
   Joined: 16 Sep 2012 Location: st.louis Points: 320  |
      Quote   Reply
     Posted: 26 Apr 2013 at 9:14pm |
   Also could use a pto coupler.I know the local farm store here around me had some. Do a serch
   mlpankey
   Joined: 13 Sep 2009 Location: Vols country Points: 4580  |
      Quote   Reply
     Posted: 27 Apr 2013 at 2:58pm |
   Mack's telling a good way to do it . Its the way i have done it and it has worked for years.  Mack is a experienced puller and machinist/ fabricator in my opinion capable of anything including making his own cylinder head.
   Ihateillinoisnazis
   Joined: 15 Jan 2013 Location: By The Lake Points: 273  |
      Quote   Reply
     Posted: 29 Apr 2013 at 11:45am |
 Thankfully your opinion is worth so much around these parts....  |
   cotncrzy
   Joined: 07 Oct 2009 Location: TENNESSEE Points: 599  |
      Quote   Reply
     Posted: 29 Apr 2013 at 12:27pm |
     Have you removes some of the brass shims around the clutch? I am still running mine, have to remove shims occasionally. Next adjustment will be to remove
     C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
| Forum Jump | Forum Permissions  ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
