Hand clutch slip
bmartin55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmartin55 Quote  Post ReplyReply Direct Link To This Post Topic: Hand clutch slip
    Posted: 13 Apr 2013 at 8:00pm
can i bolt my clutch solid.   it went sliping today at the pulles. dont really want to use it..can i take that trane out..  i need to lose weight any   way''thanks  bob  Smile   lol weight
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2013 at 10:15pm
Take it out, use another hub like the clutch bolts to and put it on input shaft then bolt the two togather.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmartin55 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2013 at 10:21pm
mack..wher can i find a hub to do that with...can i take trane out ..
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2013 at 7:24am
I should have one or use two clutch hubs which I also have.  MACK
firephight View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firephight Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2013 at 9:14pm
Also could use a pto coupler.I know the local farm store here around me had some. Do a serch
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2013 at 2:58pm
Mack's telling a good way to do it . Its the way i have done it and it has worked for years.  Mack is a experienced puller and machinist/ fabricator in my opinion capable of anything including making his own cylinder head.
Ihateillinoisnazis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ihateillinoisnazis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2013 at 11:45am
Thankfully your opinion is worth so much around these parts....
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2013 at 12:27pm
Have you removes some of the brass shims around the clutch? I am still running mine, have to remove shims occasionally. Next adjustment will be to remove
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
