Hand Clutch fix |
TennMatt1 ![]() Bronze Level ![]() Joined: 12 Oct 2015 Location: Southern KY Points: 71 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Nov 2015 at 7:55pm |
Anybody have a pic of a hand clutch on a wd 45 bolted together??? Mine is slipping and was told to just "bolt it together". What all is involved and what do I need? The way they talk its rather simple. Thanks for the input.
allispuller ![]() Bronze Level ![]() Joined: 12 Nov 2012 Location: illinois Points: 194 |
I don't have a picture but it is rather simple just split the tractor between the rear end and the housing after draining the fluid in the housing and there will be a pto drive gear bolted to the clutch and just get another gear like what i bolted to the clutch and and grind the lip off of both and bolt them together and put the tractor back together
I am talking along the lines of from the top cover. Said I needed a right angle drill and just drill through the clutch itself and put bolts in it??? Just wondering if that's the case?
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
If ya want to do it that way, forget the drill and get the welder out!
Ken(MI) ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Lansing, MI Points: 619 |
Or you could just use one of these and forget about bolts. Edited by Ken(MI) - 03 Nov 2015 at 7:37am |
Where you get one of those splined shafts?.. IM gonna replace the clutch and all first of the year so I don't wanna split the tractor right now,just don't have time to before tunica.
Larry(OH) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Shreve Ohio Points: 1580 |
Kens piece is very nice and well built. CHeap enough also. Got one in the cabinet for future use
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact* I can explain it to you, BUT I cannot understand it for you!! |
Call me for one, 517 712-1896
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3926 |
if it was drilled and bolted int the right place could it be un bolted to go back to daily farm chores ? or would it ruin it ? my wd slips pulling on hard dirt but never seems to plowing or pulling impements that spool looks like the best way for a dedicated puller
Well I went to a pull today and it was on solid red claythat was like super glue!!!! I slipped bad in 4500 as the tractor just stopped at about the 250' mark....Time to do something.
dawntreader74 ![]() Orange Level ![]() ![]() Joined: 28 Oct 2013 Location: Manteno Points: 1770 |
can't you just take some of the shims out an titen it up some would work a lot better
Take top cover off and drill a 1/4 hole through all the plates with a magnet under drill bit. Place bolt and nut through hole and go pull. MACK
