Hadely PA Pull 5-22-21
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Topic: Hadely PA Pull 5-22-21
    Posted: 23 May 2021 at 10:04pm
Folks,
RPM check station:
Edited by Sugarmaker - 23 May 2021 at 10:08pm
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 2:38pm
so how did everything go
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 6:47pm
Hud, Folks,
It went well.
3500 lb. Division 1:
  I pulled the Allis WZ, got first place 306 ft, Only one other in class, Allis WC pulled 250 ft.
3500 lb. Division 2:
 I pulled the WZ , got first place at 316 feet. two others in class, Farmall C and Oliver 66, at 312, and 256 feet.
4000 lb. Division 1.
 Jim pulled the WZ with added weight to first place at 212 feet. 5 others in class including me with the WD 45 and I came in dead last. Tried the right side of the track and it was soft. Bad move on my part.
4000 lb Division 2:
 I pulled the WD45 233 feet beating Jim on the WZ at 221 ft followed by three other pullers at 212, 205 and 198, on Ford 961, Farmall H and a Farmall C.
5000 lb Division 1:
 Jim pulled the D17  293 ft for 3 place,  he missed second place by 2 ft, the 961 Ford got good traction and won the class at 345 ft. (I think I need to get the front end a little lighter)
5000 lb Division 2:
 Jim finished in 6th, missing 5th by 8 feet, first went 343 ft on a Oliver 88 to 343 ft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 8:05pm
Folks,
We really did pull!:)
