H4 Water pump
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Topic: H4 Water pump
    Posted: 08 Jun 2016 at 1:11pm
Started my h4 today to move some dirt. After about 10 minutes she started to get hot. Let her cool down and added 2 gal of water. Fired her up and ran it for 30 minutes and she started to get hot. Shut if off to see what icould see. There is antifreeze coming out around the water pump shaft. Looks like I need a new water pump. Anyone know what the part number Is and a good place to get it cheap. mine is a gas engine. 122 I believe. I know the fuel pump on a 190 is the same. don't know about water pump. didn't know if it would be wise to replace the seal or a new water pump. thanks norm
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2016 at 4:36pm
Check Ivan at Sumerix or Minn Parr.
Good Luck!
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2016 at 6:20pm
does your h4 have the gas g2200 in it ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2016 at 6:35pm
Hello Randall. It is a Gas model. I took if off this afternoon. Bearing is bad which I think took the seal out. Didn't know if theres a kit for it or I need a new one. Havent found anything yet. thanks norm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2016 at 7:25pm
buy a new one Norman. better off that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2016 at 9:31pm
Been trying to locate on one the net at a decent price. thanks norm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2016 at 10:26pm
give general gear and tractor a try. they are located in Idaho. 1-800-531-9021  Not sure if they deal in water pumps or not.
This page was generated in 0.176 seconds.
