H4 Crawler |
pinball
Joined: 28 May 2014 Location: missouriu Points: 6458 |
Topic: H4 CrawlerPosted: 27 Mar 2017 at 8:34am |
My proofmeter is gone on my machine. trying to see if its electrical driven or cable driven. I looked all over around the dist and cant find anything that resembles where a cable would go to. I have looked all over and just cant seem to find anywhere a cable would go. So could someone look at there h4 and tell me how theres is. thanks norm
John(IN)
Posted: 27 Mar 2017 at 8:50am |
I'm not sure on an H4 but on my HD4 the cable connects to the rear of the alternator
Learn something every day!
Randaleky
Joined: 17 Aug 2011 Location: belfry, ky. Points: 427 |
Posted: 27 Mar 2017 at 10:01am |
Since the d2200 diesel and gas are basically same engine except for the block. I believe it would connect to the back of the alternator. that is the most simple way to see rpm of engine in my opinion.
Randaleky
Posted: 27 Mar 2017 at 10:02am |
sorry , not block but head..
pinball
Posted: 27 Mar 2017 at 10:03am |
Hello John. Are you saying there is an electrical wire from your alternator or a drive cable. thanks norm
Randaleky
Posted: 27 Mar 2017 at 10:38am |
Mine has a drive cable Norm.
pinball
Posted: 27 Mar 2017 at 4:12pm |
So I checked the alternator. It has a delco alternator same color as rest of the machine but don't know if its original or not. On back of the alternator there is a plate in the middle of it with 3 small screws holding it on. so I'm guessing that's where a cable would go. Was looking for a threaded collar . guess its behind that plate. still not sure as I haven't take the alternator off yet and the manual shows some sort of a gear that maybe goes in where that plate is. if so that gear is missing. just still not sure. thanks norm
pinball
Posted: 27 Mar 2017 at 7:28pm |
I found an alternator for the h4 that shows the drive for the proof meter on back of alternator. mine is missing but now I know what I am looking for. thanks norm
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35666 |
Posted: 27 Mar 2017 at 7:31pm |
Parts are still available I believe thru Heritage Line for this mechanism. My 180 has the same style drive on it.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42266 |
Posted: 04 Apr 2017 at 7:24pm |
You might find a electric unit easier to find - my 715B TLB uses a 3rd tab on alternator to run tachometer and a hour meter is electric and uses a pressure switch on oil line to energies it .
