H4 ALLIS PROBLEM
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Topic: H4 ALLIS PROBLEM
    Posted: 29 Aug 2014 at 5:51pm
Took the track off the right side of my allis 4 crawler. Didn't see this when I bought it. it runs okay but wont hold any oil. Don't know if I can have iot built back up or just fiond another case. anyone have one. Norm004.JPG
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2014 at 7:45pm
Ah yes the outboard bearing and seal area - common problem - or should say nothing new on machines with no outboard support to axle .
 Remove the housing - take to machine shop that does truck transmissions and such , they will bore out case - install a steel machined piece to hold bearing and seal - then weld it to cast .
 Problem fixed - both sides of my HD 4 were done this way - one before i bought machine and I had one done . I also  had this done on my FD5 dozer.
Will say get it fixed right as the bull gear and top gear shaft - drive and driven - will choke you on price if you have to find them .
Edited by Coke-in-MN - 29 Aug 2014 at 7:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2014 at 8:01pm
I am in the process of taking it off now. having a heck of a time getting the snap ring back to the center. everything is loose except the 4 bolts inside but cant get to them until I get the clutch out. I would like to find another case but I thought about taking it to a machine shop. not sure what either would cost but tears will flow anyway. thanks norm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2014 at 6:48am
Memory has it I paid around $500 for the machine work on HD4 case , found one used one but that case had same problem with loose bearing race area but held seal .Passed on that .
