h3
lost in h3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost in h3 Quote  Post ReplyReply Direct Link To This Post Topic: h3
    Posted: 10 May 2024 at 11:12pm
well folks got the h3 running without back firing, missing, governor surging etc.etc.
now the problem is no rpm's. it runs smooth and idles great but i just can't get greater than about 1700 tops. no binding on leakage and carburetor is good. i have the governor
i think correctly but just not getting the rpm's it needs at high idle or under load.
thank you
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2024 at 9:40am
Rated RPM was 1650.    Nebraska test showed maximum RPM of 1806. You’re not far off. Perhaps you need a stronger spring on the governor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2024 at 10:28pm
grab the governor rod by the spring and try to move it further open.. see if the carburetor rod / arm is fully stroked.... like mentioned, this may be normal.
This page was generated in 0.114 seconds.
