h3
lost in h3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost in h3 Quote  Post ReplyReply Direct Link To This Post Topic: h3
    Posted: 24 Mar 2024 at 9:43pm
I'm finishing upFile Upload a total rebuild (everything) on a 1960 h3.
Question. Should you get full rpm's at full throttle under no load. Mine rev's up but not all the way unless i manually move the governor.
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2024 at 6:40pm
Have you tested the RPM at full throttle? I believe governed RPM is 2000. You would always be able to speed it up by manually moving the linkage against the spring tension in the governor. You would be able to speed it up much higher than 2000 that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost in h3 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2024 at 11:47pm
Thank you for suggestion. I guess my first plan of attack is to get my tack working properly so I know where I'm at rpm wise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 6:33am
Rated/full load speed of 2,000 RPM means the no-load high idle speed is 2,200 to 2,250 RPM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 8:20am
I bought one of these digital tacks for $15.  You stick a piece of reflective tape on the shaft and point the little meter at it... Works great... We were testing PTO speeds on a pump.. I also checked the drill press / lathe / band saw blade.. etc.... very handly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost in h3 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 10:18am
that sounds good. cheap!
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost in h3 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 9:57pm
what is high idle compared to  normal idle?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2024 at 5:13am
High Idle is No load maximum RPM, governor Limit.
Will add, as a industry standard, for those engines with advance mechanisms, this keeps those on the Idle low power control components of governor at No advance.
Edited by DMiller - 27 Mar 2024 at 5:40am
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2024 at 1:16pm
AC released a service bulletin regarding this issue, let me see if I can dig it up! ~ Orangeman
Edited by orangeman - 27 Mar 2024 at 1:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2024 at 2:54pm
High idle of 2200-2250 RPM.  Low idle of I suppose 400 to 450 RPM.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2024 at 12:18pm
Make sure throttle is pulling  linkage against stop bolt head. Throttle linkage has a adjustment to make this happen if not . This is where it all starts to happen .
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost in h3 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2024 at 6:54pm
Thank you for the reply Fred. I'll give it a try, currently waiting on a tachometer.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2024 at 8:24pm
Confused I am confused (quite easily actually) Confused
Does it stay at no advance at high idle until load is applied? Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2024 at 6:18am
Understanding how to adjust and get proper spring tension on spring for high idle is must other wise  tachometer is useless .A shop manual has all this in it including complete adjustment of Gov.   D-15 is same .
   All the H 3  and HD3 I seen had tacks .
Edited by Fred in Pa - 29 Mar 2024 at 6:30am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2024 at 6:39am
Ignition timing advance mechanism is strictly RPM activated. It cannot and does not sense what the engine load is. The advance's "curve" is designed to work with the engines compression ratio and performance at low speed for best lugging ability.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2024 at 9:16am
Yup. Unless there is some sort of vacuum sensing apparatus, which I don't believe these engines have.
Thus my confusion/misunderstanding/misinterpretation of DMiller's statement above Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2024 at 12:26pm
Did you check the adjustments
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost in h3 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2024 at 5:49pm
Fred
Haven't did anything for a couple of days, Cold and raining here. I got tach, and high idle is seventeen hundred and low is eleven hundred. There is very little response between the two. I know i can get idle down on carburetor but see know way to raise top end. Would like about 2000rpm'
Jollymon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jollymon Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2024 at 9:10am
Hello, new to the group. Can anyone give me an idea what an H3 is worth?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2024 at 11:17am
Welcome to the forum! I suggest you start a new thread and the title will likely catch more response. The more specific you can be the better information results you will receive.
Cheers!
