H3 Steering Clutch
Pgriswd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pgriswd Quote  Post ReplyReply Direct Link To This Post Topic: H3 Steering Clutch
    Posted: 28 Apr 2025 at 7:30pm
I rebuilt the steering clutches on my H3 and reassembling. Right side went together like a champ. The left side though is almost back together but the drive spline will not slip into the clutch. Using bore scope, it looks like the splines line up with the clutch on the top, but on the bottom, the splines are not lining up and won’t slip in…I am at a loss…any suggestions?
Edited by Pgriswd - 28 Apr 2025 at 7:41pm
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2025 at 8:37pm
Do you have any way of posting pictures of the view through the bore scope?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pgriswd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2025 at 2:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pgriswd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2025 at 2:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pgriswd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2025 at 3:00pm
I removed both clutch packs and found the splines are different, so I guess there is a left and right side and I put them in backwards.  I haven't reinstalled but I think that is the issue - the drive spline and clutch packs are matched.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pgriswd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2025 at 3:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pgriswd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2025 at 3:09pm
I think you can see the difference in the two packs
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2025 at 7:54am
The distortion of the photos makes it a bit difficult to tell for certain, but it appears that the the splines actually vary in width. Is this correct?
Thanks for the feedback Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pgriswd Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2025 at 4:49pm
They are but it looks like wear
I swapped the left and right. The right went in and the left is still not fitting
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2025 at 9:32am
Any progress?
I downloaded an H3 Service Manual, it isn't very clear; are the shafts reversible?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Pgriswd Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2025 at 3:30pm
I took the clutch apart and worked with only the hud and shaft so I could see. Once the hub is bolted up to the flange, the shaft is out of line with the hub..not much nut just enough that the shaft won’t insert. Not sure how that happened but probably explains the wear on the hub. I am thinking on shim the clutch on the flange to fix the alignment issue. Will try to post pics.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Pgriswd Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2025 at 7:26am
Hello all
Thanks for the advice and I got it in. Still not sure why there is a mis-alignment. Just need to decide if I want to shim or just bolt it up. I guess it’s been bolted up that way for 60 years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2025 at 2:49pm
Glad you got it back together and thanks for the feedback Smile
This page was generated in 0.219 seconds.
