H-3 Locks for Idler Adjusting Screw
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Topic: H-3 Locks for Idler Adjusting Screw
    Posted: 13 Aug 2013 at 5:41pm
Anyone on here parting an H-3?  I am in need of two locks for the Idler adjusting screw.
These would  be for the early design which carried the 1.250" B-7 threaded adjuster.
They could be machined but likely cost prohibitive.
Please send a PM with price and availability.  Thank-you...Orangeman
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2013 at 8:17pm
CAN YOU POST A PIC OF WHAT YOU NEED? OLD ONE OR LOCATION SHOT ?
tom38 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom38 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2013 at 8:49pm
could anyone tell me if any other radiator will interchange with a H3 gas, or does anyone have a radiator & how much. thanks a lot. tomkat
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2013 at 9:12pm
I would hazard a guess, that a d-15, or d-15II radiator would fit.  measure the distance between the 2 bottom mounting holes, and I'll see if it matches my d-15II.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom38 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2013 at 10:20pm
hi, my bottom holes are the same as the top ones & they are 19 inches from side to side. the radiator is 21inches tall with the top water port is in the middle & the bottom one is on the left.   thanks tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2013 at 5:21am
Bottom holes I am referring to are the 2 tabs, that stick out, bottom, forward of the radiator, 1/2" holes, I think.  I'll try to measure the old radiator out of my D-15-II, when I go get the tractor to cut hay today.  Otherwise sounds like the same radiator.
Edited by DiyDave - 24 Aug 2013 at 5:22am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2013 at 6:29pm
My radiator off the D-15II is a tad taller, I think, than your H3, tab holes are about 13-1/2" OC apart.  Double check the height measurement, from the cap gasket surface to the bottom of the radiator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom38 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2013 at 8:40pm
diydave   my bottom tabs are 13-1/2" apart & the height from the top of the filler neck to bottom of the bottom tabs is 23-3/8", I also noticed on the top tank in yellow crayon like from a junk yard,is AC D14.also on my rad. the side tabs as I call them are 6-1/4"apat & they are 3-1/4" up form the bottom of the rad. these are threaded nuts which are 5/16x18thread &these are what attaches the rad. to the 1/4"plate that goes around the rad.from one side around the front to the other side & is about 25" tall & attaches to the frame of the dozer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2013 at 5:32am
Sounds like you found what to look for radiator wise.
