H3/HD3 Missing serial number |
CJWJ
Topic: H3/HD3 Missing serial numberPosted: 27 Jul 2025 at 1:58pm |
I've looked all over my H3/HD3 Allis Chalmers for a serial number but cannot find anything that correlates to a serial number. I'm sure this tractor was made in the 1960s but I can't find any indication of the number of hours on the machine. Sharing this photos in case anyone understands what it means -- DC23S is imprinted on the right side (pictured). 11913 is engraved on a plate behind the blade. GDN16802 F on the muffler or exhaust.
. Hoping to list this for sale.
wade89
Joined: 12 Feb 2018 Location: Northern MN Points: 225 |
Posted: 27 Jul 2025 at 2:05pm |
That’s a casting number. The serial is stamped into the bell housing of transmission where it bolts to the engine. Should be on upper left side as you sit on it.
CJWJ
Posted: 28 Jul 2025 at 12:58pm |
I think I found it—H-2296-R -- still unclear on if it is a 1961 or 1962.
Thanks(1)
Posted: 28 Jul 2025 at 1:14pm |
1961 build
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1124 |
Posted: 28 Jul 2025 at 6:17pm |
That is the engine number
Posted: 28 Jul 2025 at 8:47pm |
Chassis s/n began at 1001. Gas engine s/n for an H-3 also began at 1001. So, figuring there weren't many HD-3 diesel engines built, it still probably makes it a 1961 chassis build. 1962 models started at 3199. I don't think they made 900 diesel versions in 1961. But who knows? Maybe the HD-3's had chassis serial numbers all their own?
Edited by DrAllis - 28 Jul 2025 at 8:56pm |
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 29 Jul 2025 at 7:48pm |
Tractordata lists the H3 and HD3 separately, but list the same Serial Number Range for each year, H3 and HD3. G |
Alex09(WI)
Joined: 15 Mar 2012 Location: CECIL WI Points: 1777 |
Posted: 02 Aug 2025 at 10:45pm |
YOU NEED THE TRACTOR SERIAL #, THE PIC YOU POSTED IS THE ENGINE SERIAL #. I just had H3 #9866 pull up to my store last week with engine serial #H-2596-R. Engine appears to be original based off paint, etc. I believe the H-xxxx-R format is for the crawlers with G160 engines that started at crawler serial #6959. The 149 engined H3 crawlers have engine serial # of 3-xxxx-R
Edited by Alex09(WI) - 02 Aug 2025 at 10:46pm |
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
