H3/HD3 Crawler Loader Bucket Needed
BradinNC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BradinNC Quote  Post ReplyReply Direct Link To This Post Topic: H3/HD3 Crawler Loader Bucket Needed
    Posted: 15 Mar 2018 at 8:49pm
I'm looking for a H3/HD3 loader bucket.
Thanks in advance.
Brad
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 3:58pm
Old one failed or just worn slick?
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 6:48pm
I doubt that a bucket from hd4 would fit ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BradinNC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 8:59pm
They guy I bought it from a few years back used it to clean manure from his dairy barn. It's rusted out and bent up.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2018 at 7:08am
BradinNC-  There is another option to consider if you are unable to find an H3 bucket.  Drott company produced a small 4 N 1 clam bucket that was equipped for use on the  International T-340. The mounting brackets on the Drott are lite and would need to be reinforced/reworked to mount to the loader boom of the H3/HD3.
Can supply a Drott number if you head in that direction.
On the H3 and HD3 there were options on the bucket and attachments that could be equipped  as follows:
1. 60" dirt bucket
2. 66" material bucket
3. 80" snow bucket
4. Dozer Blade - yes AC made a dozer blade to pin in place of the bucket -very few produced.
For Material Handling for use on the H-3 the following were offered:
1. Log and Pulpwood Tine Forks
2. Grapple Hook
3. Pallet Tines
4. Midwestern Manufactured Side Boom for Pipe Laying
Yet another approach would be to go salvage hunting for an Allis I-60 or I-600 as both machines used either a 3/4  or 1 yard struck buckets.  The mounts would need to be re- worked as the out to out dimension of the loader boom on the H-3 - HD3 is narrower than the loader boom on the AC I60. I 600 or I 615.
HTH's - what a wonderful small crawler the H-3 HD 3's were in there day!
Orangeman
Edited by orangeman - 17 Mar 2018 at 7:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2018 at 7:27am
Or you can go the same route I did and rebuild the old bucket. Is intimidating to start but mine is working strong these days.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 8:38am
Another option is make a face plate to fit on loader arms - then use skid loader attachments on that to have interchangable tool holder .
 Son has done that for utility tractors and compact tractors - makes a adapter plate to fit machine and they will handle most newer skid steer buckets as they are now universal mount (almost)
 He has also made new buckets IF he has a old bucket to get measurements from - or repair units if there is enough left to have some structure to build from .
