H3/HD3/653
Message Reverse Sort Order
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: H3/HD3/653
    Posted: 05 Mar 2019 at 7:44pm
the undercarrage parts are the same - track and rollers - the upper support roller is also but the tower it mounts to differe to inside or truck frame to outside location - sprockets are also - but hunting parts is going to be a needle in a haystack look to find parts
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 5:39am
H3 and HD3 are basically the same as a D-15 farm tractor power train. 653 is a heavier crawler.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 7:58pm
My wife is works in a print shop and is making books for me tonight so I can compare H3/HD3/H4/HD4/653/652 etc..
Can't fix stupid
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 7:37pm
I would like to know as well
My bet is there may be some if not all with the h3 to hd3 but not 653
HD3
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 6:37pm
Parts manuals for them are available to view on Minnpar's site, if you want to start comparing part numbers.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 6:12pm
Is the driveline the same as the H3/HD3s? (Tracks and assembly)
Can't fix stupid
