H-3 Gas Crawler Dozer |
BobPaulusCentrOH
Bronze Level Access
Joined: 11 Sep 2009 Location: Lancaster, Ohio Points: 184 |
Topic: H-3 Gas Crawler DozerPosted: 07 Sep 2021 at 4:32pm |
Have 4 cylinder gas, and was wondering if the 149 gas engine when used on this machine, had the full flow oil filter like D 15 Series 2? If machine has full flow oil filter, does that mean it is a 160 cu. in. engine and not 149 cu. in. gas engine?
Thanks in advance for a reply.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25224 |
Posted: 07 Sep 2021 at 4:55pm |
my guess it's a 160.. sniff,sniif. always wanted one 'sister' to my D-14s.....
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5274 |
Posted: 07 Sep 2021 at 7:20pm |
I have seen the full flow system on many 149 engines. Look at the serial number behind the air cleaner hose, or sometimes on the flange to the bellhousing on the upper left side and it will tell you the CID when it left the engine factory.
