h3 fuel tank
orange80 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange80 Quote  Post ReplyReply Direct Link To This Post Topic: h3 fuel tank
    Posted: 18 Mar 2024 at 3:35pm
hi everyone im new here just picked up a h3 crawler that needs a fuel tank i was told h3 was based off d14 and d15 tractor i was curious if anyone could confirm if a tank off a d14 or 15 would fit my h3 thanks, eric
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2024 at 3:57pm
The D15 tank would be the right fit. A D14 tank may work but is narrower than the D15 tank and would not match up the the hood panels.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB(wcIL) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2024 at 7:09pm
A dozer tank has a tube at the bottom sucking from the center of the tank to the sediment bowel in the corner.  Yes a D15 tank will fit and work, but you might run out of fuel on a steep hill side.  We have a H3 and I can see the tube in the bottom of Our tank.  Andy
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2024 at 7:27pm
I have a good D15 tank available here in Maryland, very near Gettysburg, PA. PM me for details.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2024 at 8:06pm
[QUOTE=AMB(wcIL)]A dozer tank has a tube at the bottom sucking from the center of the tank to the sediment bowel in the corner.  Yes a D15 tank will fit and work, but you might run out of fuel on a steep hill side.  We have a H3 and I can see the tube in the bottom of Our tank.  Andy[/QUOTE
Had that problem on an older JI Case dozer using a farm tractor tank. I silver soldered the tube into the center of the replacement tank and it discharged to a remote mounted sediment bowl and filter. Not original but worked well.
That's All Folks!
This page was generated in 0.179 seconds.
