H-3 Final Drive Lube Recommendations
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Topic: H-3 Final Drive Lube Recommendations
    Posted: 02 Sep 2013 at 8:27pm
Guys:  Looking to freshen up the oil in the final drives.  I got the plugs free assuming they should be full up to the plug level.
Anyone have a good recommendation for the lube for the final drives?
Appreciate any insights... Thank-you Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2013 at 10:28pm
I would use 80-90 wt gear oil. HTH Tracy Martin
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2013 at 11:07pm
the 90# or 85/120  gear lube - If you never had the lower case open it might not be a bad idea to check IF any debris is settled into lower part of case.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2013 at 4:02am
Guys: This machine is a 1961 and has the heavy cast final drive pans on it.  As always, thank -you for the excellent information.  Orangeman
Old Yeller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Old Yeller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2013 at 9:48pm
Orangeman, I am brand new to this forum but have done a little snooping around before joining and see that you have a lot of good posts regarding your 1961 H3 dozer.  I just recently purchased a similar dozer and haven't even been able to haul it home yet.  I have ZERO knowledge about dozers and do not consider myself a "mechanic" but I am looking forward to learning while I try to get a few small projects done.  I did find an Operators Manual (TM-268) that applies to the H3, and calls for SAE 20-20W oil in the final drives.  Since it looks like you might be going with the gear oil, I am wondering if the manual is wrong or why folks are recommending the gear oil.  What did you end up using and how is it working?
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2013 at 7:26am
The owners manual for my HD6G says 50 wt motor oil in summer and 30 wt in winter. I have been using universal transmission/hydraulic oil. Most people on this forum use 90 wt or 85W140 GL5 oil. If your final drives leak I can understand that the heavier viscosity oil might leak out slower. I owned an HD7 where the previous owner used wheel bearing greese. That didn't work as I had to replace the final drive bearings.
This page was generated in 0.093 seconds.
