H3 Factory Three Point Questions
Likes Old Iron View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Likes Old Iron Quote  Post ReplyReply Direct Link To This Post Topic: H3 Factory Three Point Questions
    Posted: 29 Jul 2018 at 9:04am
Hey guys, first off, thank you all for all the information on here, I learn a lot from this site.  I'm in the process of adding a factory original three point hitch and PTO to my H3.  After a lot of searching and travels, I've found all the brackets/parts/hydraulics and got them installed except for the lift arms and vertical adjusters.  I've reached a point where I need a little advice.  The factory manual and diagrams say the 3 point on this machine was rated as a category 1 or category 2 .  I plan on putting a 5-6' rotary brush cutter behind it:
1.) Which category would you set it up for?  Cat 2 for strength and bush down or stick with Cat 1?
2.) Most lift arms/adjusters I see in the local farms stores here are junk.  Unless you all can recommend a good source, I'm leaning more toward original Allis pieces, say from a D15 or D17, or any recommendations you all might have from other models/brands that would fit.
3.) Any body have an original H3 set to sell or willing to take some measurements?
Thank you all in advance.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2018 at 9:45am
Don't use any D15 factory 3 point components.  Everything on those 3 points are weak.  Nearly impossible to find one that has not been welded up in one way or another.
That's all I can tell you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2018 at 6:16pm
Might be easier to find a snap-coupler bell to put under it, and Lift arms for s/c off of a d-15, and an AC factory s/c to 3 point adapter.  THat way, when you take off the mower, alla that 3 point junk ain't a hangin there, waiting to get bent up...Wink
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2018 at 3:24pm
I have the factory 3 point hitch ass'y for my HD-3. it is very stout. Nothing in comparison  to the three point hitch on the 615 which is essentially a D15 set-up.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
