H3 engine needed
AC Mel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Topic: H3 engine needed
    Posted: 21 May 2010 at 12:30pm
We just picked up this H3 (litterly picked up) for our Allis Chalmers tractor collection. The previous owner ran it out of water and fried it. He took it to somebody that new somebody that new somebody else that could work on it. After 2 years he went and claimed all the parts back. All the engine parts have rusted almost beyond recognition. We think it will be easier to start with another engine. The serial# is 3127 which indicates it to be 1961. Hoping someone knows where there might be some parts here in N.Ca.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2010 at 12:44pm
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2010 at 6:13pm
with I had the out fit you have.  Iam going to pick up h3 this weekend a parts dozer.  How bad is the motor ? is the block and crank any good ?
160 CA 920diesel 5020 HD-3
Kipn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kipn Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 8:24am
That would be the same motor that is in a D15 gas, a 149cid. They used them in other things besides tractors also like generators and water pumps.
1961 H3
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 10:50am
Kipn, thanks for your reply, yes we're always looking for AC farm equipment for our collection to. Our biggest resource area is the Sacrameto valley here in N.Ca. Our problem is if we find something to complete we don't want to dissmantle it for parts we're going to save it until we find the one missing part to fix it (you no the one part that this planet is out of), but it's fun lookin
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 10:34pm
Kip, The engine in an H3 has a fuel pump on them, so if you get on too steep up a hill you won't run out of gas. The D15 engines do not have the opening for the pump. By the looks of the block in the photo it looks like it would be perfectly good to use.
blrott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blrott Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 6:28pm
just bought h3 with 6 way blade. do you know where the serial number plate is located. cannot find. any info would be great. thanks. bruce.
Bud(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bud(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 7:52pm
Bruce,
The serial number is on the left hand side of the torque tube near the engine - just like on the D series tractors.  It is just stamped in the casting, not an actual plate.  Heavy paint or years of dirt and or battery acid can make it impossible to see.  It should start with H3, followed by some more numbers.
Dave
Edited by Bud(WI) - 11 Jul 2012 at 8:05pm
This page was generated in 0.297 seconds.
