H3 dozer track pads
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Topic: H3 dozer track pads
    Posted: 30 Jun 2025 at 4:27pm
The H3 dozer that I bought is missing two track pads. They are 12 inches wide. Anyone have a couple for sale?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2025 at 9:19am
The pads that I need are actually 14 inches wide with 1.5 inch high grousers on them.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2025 at 10:28am
Dave- Berco used to carry the track pads for the H-3, HD3 crawler loader -sadly they have disappeared and are NLA.  You might check with a local track shop to see if they have a few around.  ITP has material to build the track pads up should that be needed.
Link here for more info: https://industrialtractorparts.com/
HTH's ~ Orangeman
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 12:38am
H3 , H4 , 653 , 655 , all the same bolt pattern and rails .Could get pads for loader and weld grouser bar onto them . On my HD5G to build up pads I just welded 2 pieces of rebar onto each pad for buildup .
