H-3 CRAWLER LOADER |
Post Reply |
BV
Silver Level Joined: 12 Sep 2009 Location: Bono Arkansas Points: 480 |
Posted: 20 Mar 2012 at 1:29pm |
I've been looking for a h-3 dozer without any luck but there is a h-3 crawler with loader for sale in my area, how good of a machine are these and can i get a push blade for the front to do some light dirt pushing? How much is one of these worth in good condition?
Kipn
Orange Level Joined: 12 Sep 2009 Location: Tewksbury, Ma Points: 800 |
Push blades and buckets have different frames. Putting the bucket straight down will push dirt. Paid $1500 for mine 20 years ago in rough shape. Seen them go $3500-5000
in good shape.
1961 H3
Tracy Martin TN
Orange Level Access Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10578 |
BV, They made a clam shell bucket for those also. Tracy Martin
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41274 |
Between my HD5 B dozer and the HD5G loader I could push more dirt with the loader bucket. I just could not cover a 9ft area in one pass , but as the bucket was narrower i could maintain a higher ground speed
The 5 B had a 9 ft blade and say 50 HP / My FD5 has a 7 1/2 ft blade and 72 HP but will push 3 times to dirt the 5 B did in half the time. Figure that H3 is 40 HP at tops and a 8ft blade , might be fine for finish and light work but it isn't a construction machine it's industrial grade.
"Challenges are what make life interesting; overcoming them is what makes life meaningful." |
orangeman
Orange Level Joined: 12 Sep 2009 Points: 1707 |
BV: Lots of good advice above. Here are a few things to consider. H-3 with a 1066 loader on it is a reasonably good machine if used within its design capacity - most that I have looked at have had multiple operators since their production period of 1960 - 1968 - thus multiple defects.
I have never personally seen an H-3 with a clamshell bucket on the front which is generally referred to as a Drott bucket. I believe they were out there though and if it operates correctly - the Drott bucket then I think it would be advantagous. I have a factory straight blade that can go in place of the bucket so one would have to pull the pins to mount up the blade. Wear points to consider - like any machine care is important. Be aware that the bucket on the H-3 could easily be overloaded. Because the bucket extends out in front of the machine the overloaded bucket could set up a rocking horse effect even when the machine had weights on the back. If the H-3 you are looking at is a shovel, then the machine should have a total of eight flat weights on the back. If not, recommend if you consider the machine you find the weights. Another point to consider is the C channel frame that the bottom rollers attach to. Pay particular attention to the area of the frame where the front idler ends and the gusseting that communicates the two C channels together. Dead load carried in the bucket has to be transferred to some point. The point that takes up that "dead load" is the frame where the idler opening ends and the gusseting begins. This area is particularly prone to cracking. 9/10 H-3 I have looked at have a crack at this location. That said, like any steel tracked machine metal on metal wear needs to be considered. Like Coke noted above the H-3 is designed for light duty - residential and farm work - it has a fantastic tractive potential - check out the Nebraska test for the H-3. In good condition I would say 3,500 - 5,000 consistent with what Kip noted. An HD-5G or HD6 G would easily out compete and H-3 with a 1066 loader. JMO
Post Reply | |
