H3 crankshaft pulley |
powertech84 ![]() Silver Level ![]() Joined: 17 Oct 2009 Location: Wisconsin Points: 467 |
![]() ![]() ![]() ![]() ![]() Posted: 23 Jun 2024 at 3:49pm |
Can anyone tell me the part number for the front crankshaft pulley of an early H3 dozer? I can't find the H3 in the Agco parts lookup. Most parts I've been using D14/D15 manuals, but the part numbers for the front pulley on the 14/15 seem to be different, so I would like to get the right one. Mine turned up missing since I took this apart last year. I spent a couple hours looking for it, and I know I will find it as soon as the replacement gets installed, but thats how it goes. Thanks in advance for the help.
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5665 |
Per the D-14 Parts Catalog, early D-14 used front Pulley 229698. At Engine Serial 11562 it changed to 230712. The change was 4 threaded holes were added to acommodate the bolt on coupling for the front mounted hydraulic pump required for the 414 hydraulic loader. G |
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4858 |
Also the early D15 tractors had a wide fan belt and later tractors had a narrow belt.
Thanks, but like I said, I have part numbers for the tractors.. I'm looking for the correct part number for the H3
Managed to find my Allis Dealer Parts Catalog for H-3 and HD-3. On P-8 Crankshaft Pulley for Gas is #233396 Adapter that mounts to Pulley with 4 bolts for a Hand Crank is #233401. G |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21034 |
I had to use AGCO parts books to verify, but the D-15 gas farm tractor engine is 70235043 for the pulley and 70233432 for the narrow fan belt. No wide fan belt like the D-14 was ever used on a D-15.
Thanks gary, that's exactly what I needed. I ordered a new one from steiner. Unfortunately for some reason the 3/8" belt pulley is almost $40 more than the thicker belt pulley... this project is wildly over budget as is, so might as well just keep going!
8070nc ![]() Orange Level Access ![]() Joined: 21 Mar 2019 Location: North Carolina Points: 538 |
I thought over budget is the only way it would work
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8372 |
"This won't cost that much." is the lie we tell ourselves....It's not a budget problem per say. It's that we aren't realistic when making a budget.
Fred in Pa ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
There is NO budget for something you want !!!! That you already got into.
Edited by Fred in Pa - 24 Jun 2024 at 2:09pm |
nonetheless ,still dead. If all else fails ,Read all that is PRINTED. |
